Hi All,
I recently replaced the movement for my Tissot PR50, which was a standard ETA F06.111. I now need to replace the crown as the old stem was broken into the crown and could not be re-used.
Could someone point me in the right direction in finding a proper replacement crown? I don't know the size or how/where to measure to find a proper crown.
Thank you!
On 5/4/2018 at 1:06 PM, rogart63 said:
Cousinsuk has some Tissot crowns. You would probably need a new stem also. I would think the stem is 0,9 mm .
I replaced the movement and it came with a replacement stem.
Further research shows that the stem provided is a Tap 10 Stem, I presume.
How should I go about sizing the replacement crown?
