Removing Caseback
This is a very newbie question, but I always see descriptions/videos of how to remove casebacks, but I never see one that shows the type in my picture.  Is there some kind of special wrench tools for these?  I've tried the rubber ball, I always get the ball stuck on the lugs.  I thought maybe Jaxa, but I can't seem to get things to line up with the flathead type bits.  What's the best way to remove a caseback like I have pictured?
Thank you for any advice.
Are you sure that that isn't a snap off case back ? Some vintage watches had case backs shaped like yours but they were snap off. A picture from the side might help...
If you can't manage to open it I have another suggestion that I got from a watch forum once. Use a bit of super glue and stick something like a metal tool such as a screw driver or something onto the case back. Then use the tool to rotate the case back. Then simply clean away the glue from the case back and tool. Only did it once but worked great.
All I have is one of the typical adjustable three point back wrenches, but it works pretty well on those if they aren’t jammed too badly. Just adjust it so the points are across three of the flats. Works best if you have flat points in the tool not the round ones.
Sent from my iPad using Tapatalk Pro
Here's my DIY tool I use when the sticky ball don't work.
Get a round plastic box with a flat cover, about the size of your caseback.
Cover it with duct tape, sticky side out, on one side.
Hold your watch firmly in one hand, crystal on your palm.
With the other hand place the "now sticky" side of your plastic box on your watch caseback and apply a firm pressure.
Turn both hands opposite ways, still applying a good pressure.
The caseback should unscrew.
The duct tape could let some sticky on you caseback ... clean with a q-tip and nail remover.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
    • More photos of watch for reference.
    • 1) flat jewel for wheels: picture shows a jewel with oil sink. Straight hole. Not hole 8 or 9. 2) balance jewel, olive hole: picture shows a domed jewel without oil sink. B + sizes. 3) flat jewel, olive hole: hole size 8 or 9 only. Frank
    • Hey folks, first time poster here. Starting into watch repair and swapping out a movement with another and have a donor watch. I incorrectly yanked a stem out that I assumed was a split stem but I think the case back just is hard to get off. By doing this, I can put the stem back in but it fairly easily pulls out now so I think I broke something. Not a huge deal as this was the donor but I’m hoping to get confirmation that I toasted a particular piece.  I know movements generally have a screw or push release for the stem if not a split stem so I think I just made a rookie whoopsy. The case back doesn’t have a groove for a knife nor is a screw down which is what led me to the split stem assumption… I may just need a razor blade to create a gap in the case back to get a knife underneath. On the donor I could certainly push the watch back out of the case, just don’t want to make the same mistake on the watch I’m rehabbing. is anyone familiar with this movement or can definitively tell if I broke the donor piece that holds in the stem? Not a huge deal since it’s a harvester movement for me. thanks all, looking forward to learning a lot!
    • That’s a fair point and is what’s stopped me from making a more concerted effort to open it. Since it’s got an SW200 in it, I was thinking of getting an Invicta diver with the same movement for $200 or so and messing with that first.   I was thinking that the SW200 fine regulation screw would be easy to turn to slow the watch down a bit, but maybe it’s easy to break the movement even doing something simple like that.
    • See, making new staff takes me 30 minutes and I often say that pocket watch with broken balance staff and no other problems is actially watch without problems. So fixing ypu watch is a piece of cake. Just lathe is needed and skills for working on it
