Seiko Elnix Lift Angle
Omega Cal 1337 Quartz Movement - I repaired (or so I thought) my first full movement from spare parts from not working movements. Everything seems to be running smoothly except its running probably 5-8 seconds fast per minute. Any thoughts?
New watch enthusiast from Connecticut with a focus on collecting and tinkering with vintage Omega's. Although I recently purchased a new Speedy Professional and a Tudor BB Pro Opaline. Thank you in advance for your help!
Thank you for your reply and for the advice. Let's see how it goes. Best regards, gerardo.
Little chance for a direct transfer to work, even if both movements are of exact same caliber. If lucky you might have a close match, in which case adjusting is done by adding or reducing balance weight. Otherwise its down to assortment of overcoils and hope to find a close match. Welcome here and good luck.
