Reassmble Problems - Newbie needs advice
Link
All things considered, my first tear down and rebuild didn't go too bad.
Some general things I learned:
  • Face side first!
  • Don't grab things too tight with the tweezers, two screws are somewhere on the floor
  • Don't over tighten screws, I broke one off and somehow managed to get it out
  • Take photos, don't rely on an exploded diagram
Ok so my questions. Here is the movement tech sheet I was using.
Crown set bridge. The crown locked in place but it wouldn't engage any gears. Any clue what went wrong? I'm assuming what they call the sliding pinion is in the wrong location or I'm missing tension on it? I just can't tell from the diagram what I did wrong. Photo as I assembled it:
The balance wouldn't freely spin after assembly. My assumption here is the staff didn't make contact with the top and bottom pivots? Should I have taken off the regulator to seat that jewel correctly? Did I mess up the staff? Two photos:
IMG_0133.thumb.JPG.df23ca560341210c77520f3169fb37db.JPGIMG_0130.thumb.JPG.38345e954a8ad9ebe3dcc0630b8cbc51.JPG
The gear above the crown with the huge flat head screw. I assume this isn't made to come off?
re crown set bridge - the set lever should hold the winding pinion against the clutch wheel.. ie the two parts with the ramped teeth should be forced together when the set lever and its spring is installed.
A pic without the bridge would assist diagnosis.
Balance wheel. Can only see one pivot clearly.. the other should look the same. You would usually get the balance in place and the balance bridge in position before tightening everything down gradually while making sure the balance spins. Tightening the screw in one go will break the pinion if it is not safely in its hole. If the balance spins one way and not the other then the impulse jewel is not in the fork at the end off the pallet lever. If all is in place correctly but the balance is still sluggish then you may need to clean the balance jewels again.
big screw/gear .. this is usually a left handed screw. ie clockwise to open. It is also usually very tight. This can break, especially if someone has already used force to try and unloosen it like a normal screw. I would leave it alone for the moment
good luck!
Anilv
good luck!
Anilv
Ah! It spins freely now but doesn’t come out. I guess I broke it.
Thanks for the help!
good luck!
Anilv
Ouch... well live and learn.
It is good when working on unfamiliar movements to check on the direction a wheel/gear will rotate when in use.
In this case, when the watch is wound, the gear would move counter-clockwise and potentially this could cause a normal screw to unscrew, hence the use of a left-handed thread which will only get tighter.
Most manufacturers will mark the head of a screw with 3 lines to indicated that it is a left-handed thread but there will be some exceptions.
Anilv
It looks like the pallet fork is not in the right place... It is not evenly lying / rather slanted. Is it moving freely from left to right and vice versa? (maybe it is just the angle of the photo).
Edited by rappeleur
Inserted detail pic
5aa852a1a7c30_Capture_2018-03-13-23-35-32.thumb.png.8fa62f57f42e57bce8b8e3217786e393.png
The pallet fork moves with each rotation of the escape wheel. With photo can not judge if it is evenly lying or not. However you can check yourself by gently notch the fork from both directions. If it moves with escape wheel it seems to be okay. Remind that you should check the pivot of the pallet fork before tightening the screws.
yeah, I know, I wanted to give adive to the TO "Link"  for his/her problem:
I only saw the photo and thought this might be a thing to check for him/her before taking apart the whole movement... (It may also be that the balance was just set a bit wrong in place, so that the jewel came to lie outside the pallet fork and thus couldn’t be moved by it).
For sure the pallet can't stay in the middle like that. Definitely something is wrong with that escapement.
Thanks everyone for the advice!
I think I had the pallet installed incorrectly, I was able to wind it up slightly and make the escapement tick after this try. As far as I can see in my loupe the pallet isn't damaged. For the balance, it has a tooth looking jewel, impulse jewel? where should I put this during installation? In the fork? Should the spring have any tension?
Now on to the crown. Here is a pic with the set bridge removed. What is wrong with this picture? I feel like the spring isn't in the right place. Actually I think maybe the sliding pinion is backwards?
These pics are all through a 10X loupe and my iphone, this works amazingly well.
Edited by Link
I can't spell
The roller jewel on the escape wheel should rest between the banking pins ( no tension). This can be checked with the pallet fork removed and the balance cock reinstalled. And looking between the banking pins make sure the roller jewel on the balance wheel roller table is perfectly between those pins.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
