Seconds hand slight stuttering
Chopin
I have a swiss manual wind vintage movement (50s period; unknown maker; 17 jewels) that has just been serviced. Nothing inside looked damage but I noticed the other day that sometimes there is a slight stutter with the seconds hand. It seems to only happen in one spot, I believe, for around 4-5 seconds. But that point seems to move around throughout the day/time, perhaps it advances.
What could cause this ? Too little/too much lubrication with certain parts or potential damage ? Where should I investigate this matter in the movement ?
Forgot to mention it's a 18000 movement. By stuttering I mean that when it reaches the area that it starts to do this instead of having 5 ticks it'll have 3 larger ones, or at least that's how it looks like.
Edited by Chopin
A picture of the movement and watch would help you do not say whether the  second hand is a small seconds or a large center seconds hand and if so is it  via a pinion and driven from a wheel on the third wheel arbor and held in place with a tension spring ?
I don't think It would be possible for anyone to answer your question without these basic facts I'm afraid.
Edited by wls1971
Probably what Anilv suggests, however, monitor the balance amplitude before adjusting...... the increased friction from the sweep seconds spring shouldn’t affect the amplitude significantly, but something like a reduction of 10 degrees may be typical. Monitor the amplitude throughout the 60s cycle, and check that it is consistent. If it is not, then inspect the moving contact points.
  • 4 weeks later...
