Hi All
I give up trying to find specs to get cheap crystal replacement. I have a Seiko 5y22-8A08 The glass was broken so I can't measure diameter. The thickness is 1.15mm . I don't trust measuring the inside of the case . I do not want to spend the $15 Ofrei wants, I am looking for a generic cheap alternative . Ofrei list the replacement # as Seiko 295W69LN, but they do not tell you the dimensions. The gasket looks good.
Anyone know where I can find info needed.
Thanks
Tony
you should be able to get mineral glasses cheaply enough that its no problem ordering the size you think it is as well as the size above and below that in case your measurement was slightly off. As chopin suggests cousins is a good source, but i imagine if they can offer glasses that cheaply, others can to, even the branded 'sternkreuz' arent that much more expensive.
The only issue is the thickness is a little unusual, I imagine either a 1mm or a 1.3 would not be noticeably different. if you have any of the glass left position it and judge whether you'd rather have it a hairsbreadth prouder or shyer.
Edited by Ishima
5 hours ago, Chopin said:
https://www.cousinsuk.com/
Has good generic mineral glass crystals. Not sure how much will shipping be to the US. For Europe it's around 3USD but the glasses themselves are also cheap.
Chopin
Thanks but I can glass cheap enough ...really just need to know what size
Ishima
Good Idea I do have a little piece I can use to gauge depth. I use a gauge that was made to measure diamonds ..it is extremely accurate. I guess I could buy one bigger and smaller ...But i rather be able to know exact size I need ...There must be somewhere to locate this info.
Thanks
Tony
To expedite locating the correct size I called Ofrei and they were kind enough to give me the correct dimensions ...1.2 x 29.5.  I would still like to know if there is some kind of source so I can lookup sizes for myself.
12 hours ago, adiorio110 said:
I don't trust measuring the inside of the case.
You should. Beside, with flat mineral crystal being $1 a piece, isn't really expensive ordering two contiguous sizes.
It's not the cost so much as it is I like to know and also be able to confirm my measurements. It's an OCD thing
Besides in the future when I am looking at more expensive crystals cost may become a factor.
Sent from my SM-G955U1 using Tapatalk
Edited by adiorio110
That's OK, your vernier (or digital) caliper will deal with that just fine.
Its my first attempt I am sure once I do a few I will trust the process more.
BTW should the crystal rest on top or in between the gasket
Supposedly it will rest on the case edge below the gasket. You won't find a generic 1.15mm crystal, so don't count on perfect top alignment.
I did measure 1.15 But after calling Ofrei I was told the actual measurement should have been 2.5 X 29.5, I assume this glass has been replaced before.. I did find a 1.2X29.5  That should do the trick
2.5mm makes a diver's crystal. Maybe the Ofrei person was checking A's scores.
Another reason I would prefer to do my own research.
Maybe I misunderstood..and he said 1.25 makes more sense
Im not by my notes maybe I just remembered wrong
