A new tool in my restoration arsenal
khunter
I just received another ebay gamble that seems to have paid off. An inexpensive  ($50) gold plating setup, for restoring those pesky gold plated parts that some hack couldn't keep his bare fingers off of lol. Here's a couple pictures of an old screw I tried it out on. Polished with the dremel and felt wheel before plating, I didn't try to get all the nicks out of the slot. BTW, this was just a plain steel bridge screw, not previously plated.
The electrical part is basically a 5v wall charger, a stainless anode and an alligator clip for the part. Plating took about 15-20 seconds.
4 hours ago, ro63rto said:
I should look into this myself. Got a few bits that need replating like the bezel on one of my 7a38's
Very nice piece!
Depending on the base metal you might need extra solutions, and it's all explained all over YouTube, etc, but it's super easy. The main thing is prep, the higher the polish before plating the better, and thoroughly clean of course. For the bits I'm working on that little 4oz jar of plating solution will last a LONG time, but they make larger quantities as well.
2 hours ago, measuretwice said:
That turned out well....I'd be afraid of wanting to gold plate everything in site :)
For some reason the dog has been avoiding me since I started experimenting :)
I have a few Illinois movements with gold hardware that could definitely use some TLC, I'll have to keep reminding myself that "less is more" or I'll end up with a big gold lump lol.
13 hours ago, teegee said:
Nice! You think it would plate thick enough for a bezel?
Do they have a chrome/nickel plating setup as well?
Yes they do, and I'm not sure the supplied power pack would have enough amperage for large pieces, but an adjustable voltage power supply would do just fine, Under load the voltage should be around 5-7 volts, the packaging says 8 but I think that's a little high, at least from what I've read online....
    • I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
