Broken screw in movement.
I have an old Admiral pocket watch I am servicing. I have a sheared screw broken flush on the winding gear. If I strip the movement down. Does that Visson removal fluid work to  dissolve the screw. And could this fluid attack the metal that the movement is made from? This pocket watch is an antimagnetic pocket watch. 1904
Use a warm solution of alum (aluminium phosphate) to dissolve screws. It only corrodes ferrous metals, not the plate which is made of brass. Search this forum or google for more info.
Yup I was thinking about that as well. I used to have a nice burgeon set of staking tools when I was younger it had the fine extractor unit with it. Unfornately one of my roomates had a friend over and they stole all my watch repair tools never to see them or my tools again. I need to invest in another set of watch repair tools.
Thought  of that as well. But I think this watch was serviced before and somonene may have jimmy rigged a wrong threaded screw in there. I could try to gently pilot it out. Moving slightly  clockwise  then counter clockwise, for it's the windgear screw that broke. ( spring fully unpowered)  other screws came out nicely. This was already broken and noticed the head in the caseback edge before it had a chance to fall out.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
    • hmmmm.... maybe there is a way to skin that cat 🙀 let me think on it... unless anyone else has any ideas? I left the opening in the side of the base and ring quite large to maybe allow you to grip the crown, but appreciate this may not always be possible, especially for small movements where the crown will not extend past the outer wall of the holder. I noticed this also, but after using the holder for a while I noticed that the ring/holder began to wear into shape (rough edges/bumps worn off) and the size became closer to the desired movement OD. Maybe with some trial and error we could add 0.5 mm (??) to the movement OD to allow for this initial bedding-in?
    • Hi nickelsilver, thanks for the great explanation and the links! I'll take a good look in the article.  Especially this is great news to hear! Looking through forums and youtube videos I was informed to 'fist find a case and then fit a movement for it'. But seems that's not the case for pocket watches at least?  I guess I should be looking to find some 'male square bench keys' for now. I was thinking of winding the mainspring using a screwdriver directly, but I found a thread that you've replied on, saying that it could damage the spring.
    • Murks, The rate and amplitude look OK, and the amplitude should improve once the oils you have used get a chance to move bed-in, also I notice that you are using default 52 degrees for the lift angle, if you get the real lift angle (assuming it's not actually 52) this will change your amplitude - maybe higher, maybe lower. I notice that the beat error is a little high, but not crazy high. At the risk of upsetting the purists, if the balance has an adjustment arm I would go ahead and try and get this <0.3 ms, but if it does not have an adjustable arm then I would probably leave well alone. Just my opinion.
    • Hi everyone on my timegrapher it showing this do a make anymore adjustment someone let me know ?
