Tool for removing stubborn 2-piece stems.
MrRoundel
In a previous life I worked as an optician. During that time I would use a special set of pliers for adjusting spectacle nose-pads. I ended up buying a pair of my own. Then, a couple of years ago, I had to deal with removing a stubborn stem/crown assembly from an early E. Howard pocket watch. As I rubbed my head to wake up the idea genie, I reached for those pliers. They worked perfectly, and since they have smooth jaws they didn't harm the crown. Fast-forward to last week when I had to pull the two-piece crown/stem assembly on a Wittnauer wrist watch. I grabbed those pliers and they popped it right off.  If you come across a pair, you might consider it. Mine were made by Sadler. Cheers.
Using pliers is fine but just as a reminder not all two part stems come apart in this method. Some of them have to be rotated to the correct position then the movement drops out the two stem parts slide apart. If you pull them apart by force bad things occur.
I never came across such a thing. Is it a fixing that is in modern quartz watches?
I don't think I've ever seen it on a quartz watch. I've seen it on older watches and I have a really crappy photograph. Definitely should have used a different camera and the purpose of the photograph was to show the replacement is too short.
So this is a Mido the crown comes attached with a stem. You'll notice in the photograph the opening for the crown slides into is squarish. It would make considerable more sense if I photographed it with the stem and preferably with a better camera. Which if I think about it I'll see if I can do that I still have this nightmare in my possession. So another watchmaker following standard operating procedure ripped out the crown. Upon assembly discovered that it was loose? Decided to tighten and you'll notice it's now broken. This is why I posted the comment that if doesn't want to come out use caution as trying to get these parts are very very difficult to get the replacement for the crown with its attached stem required purchasing used case and crown from ebay.
I can certainly see how bad things could happen by yanking on one of that style, believing it will pop out. I can also see how finding such a stem would be a tough "get". I'm just learning about using the Besfit catalogs to find parts for various wrist-watch calibers. I just bought a vintage Girard-Perregaux for my GF. It is missing the waterproof crown, which probably means it's missing 1/2 its 2-piece stem as well. As I attempt to find a potential replacement for the movement I believe is in the GP case - AS 1180- (I bought in a lot of watches w/o seeing the movements.), I see how difficult sourcing these vintage parts can be, so you definitely don't want to break them. Cheers.
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
