My First Strip Down - Helvetia
PhilB
Much better than my 1st attempts a long time ago,  I destroyed at least 10 or so before I ever got one back together and running.  I would only say that it is safest to get the balance wheel and bridge out of the way and into a safe place as soon as possible.  A brilliant 1st attempt.   :thumbsu:
I tend to fit the Barrel Bridge after the Train wheel bridge, makes it a lot easier to align the pivots........
Just finished an FEF 380 and you have to fit the pallets and escape wheel first as the centre wheel sits over them, with its own bridge.....
Ok,
I've removed the balance and pivots.
Fitted the winding mechanism and main barrel, great wheel, barrel bridge, ratchet wheel and crown wheel.
When I turn the crown a few times the crown and ratchet wheel turn but nothing else happens.
I haven't opened the barrel during removal and the watch was working before stripping.
What should I check for first?
Last night I removed everything bar the winding mechanism
This morning I've
Fitted the train wheels and bridge - everything seem to move freely
Fitted the barrel and bridge
Fitted the crown and ratchet wheels.
The movement doesn't start when I turn the crown
I can feel tension in the spring but nothing spins.
What can I check first?
Ok i've made some progress.
I opened the barrel again and too a good look at the spring without removing it but couldn't see any breaks.
Once refitted I loosened the train bridge a little and the movement started, so I may not have the jewels in the train bridge aligned.
I would firstly check the regulatoe index arm hasn't been nudged to either maximum, as this can lock the balance, check the impulse jewel engages the pallet fork. If this is wrong the balance wheel will lock on it's return swing.
After that it's a case of working back checking pivots, end shake and side shake, check all jewels.... the list goes on....................
when I say running I mean the barrel is spinning the train wheels, I've still got the paletts, balance wheel and calendar stuff to fit.
On the plus side, my tweezer handling is getting much better.
Thats what it's all about Phil, practice! You are doing great, you don't get anywhere by rushing so just go at a pace you are comfortable with.
I would firstly check the regulator index arm hasn't been nudged to either maximum, as this can lock the balance, check the impulse jewel engages the pallet fork. If this is wrong the balance wheel will lock on it's return swing.
The first problems I came across when starting out was actuall getting the balance impulse jewel to engage the pallet fork correctly.... see this link .....
http://www.timezonewatchschool.com/WatchSchool/Glossary/Glossary%20-%20Escapement/Glossary-Escape-Animation/glossary-escape-animation.shtml
Basically the impulse jewel must be on the side of the fork where it is against the curb pins.....
Edited by Legarm
When you add the Balance Wheel, give it a few puffs from your blower to make sure it's turning freely, then make sure you add several more turns to the Crown mate.  That caught me out to begin with, then I realized that I'd only put about a 1 turn from a completely unwound Mainspring :p  Some of the cheaper movements need a bit of spring tension before the olde balance starts a-spinning.
Secondly, have you cleaned and oiled the jewels of the Balance yet?  There could be some dirty holding things up.
But MOST IMPORTANT is to check your Balance is running free, and those pivots are aligned with a puff from your blower.
Excellent job Phil.
One thing, when installing the balance wheel, if you nudge it (puff of a blower, gentle tweezers, just tweezers, hammer and chisel, bulldozer, etc -- sorry got carried away :) ) and it kind of tries to swing but stops right away, it means the jewel is not engaged, indicating that the balance jewel is on the outside of the pallet fork and not in its "groove".
The trick with some movements is to have the pallet fork on the extreme left position looking from the back of the fork. Then, try to place the pivots of the wheel right on its points the first time.  Direct and rotate the balance wheel to position it. Then, guide it gently with your tweezers into the pallet fork "groove" and mostly, be extra gentle and careful with the hairspring and pivots. This at least works for me and might make your life easier with that movement, but there may be a better suggestion.
Edited by bobm12
Don't get disheartened Phil, we are all very proud of your achievement.
A fridge magnet will do the trick, ALL of us have dropped screws and had to hunt for them ... finding dropped parts a skill you need to learn, just like using your tweezers.
Just wait until an incabloc jewel pings off your desk ... that's when things get real interesting :p
I haven't found the screw I lost - it was between my teezers one minute then gone the next.
I've tried the magnet but no luck. I even vacuumed the carpet and emptied the contents out but still no joy.
We all have a Black Hole in the room where we do our watch making ....... I have a magnet with an 18kg pull on it, but stuff still disappears......
If it makes you feel any better, I've lost an assortment of screws, ruined a hairspring, lost cap jewels, lost three, yes three click springs and broken two set bridges (dumb, dumb, dumb). And I've yet to complete my first watch (though I'm close). It's been very frustrating at times, but each failure and mistake has been a learning experience. See if you can get yourself a spare movement for parts. Don't give up. And remember to have fun.
    • Just picked this up earlier today. This find just about epitomizes vintage watch collecting for me and what really keeps me going. Hit 2 antique malls today and saw a couple of pieces at the first one but just nothing that I needed. At the second one saw a Accutron 218 but it was 20 minutes behind the actual time. These "malls" have numerous booths of a variety of sellers who likely go in once or twice a week. Considering that that watch should be within a couple of seconds a month, I figured it hadn't been phased so passed on that for now knowing it would need work to run correctly and the price tag. Then I found this Excelle in a display case. I never heard of the brand, but in was an auto and had a little heft. It turned out to be 40mm lug to lug, 35.3mm case width, and 12.3 mm thick. On the spiedel once size fits most flex band. At $10.80US with tax I immediately pulled the trigger with nothing to lose. Before pictures: I spent a nice 30 minutes taking it out of the case and running that through the ultra sonic replacing the crystal and gasket and recasing, but spent five minutes first getting it running close on the timegrapher. Had a new crystal already in stock. I probably could have sanbed and polished the old one, but for $3 there is nothing like a new acrylic that makes a watch pop, in my opinion. The caseback gasket was hardened and just glad it wasn't tar. Changed that as well. Here is the after Pic on a temp black strap while I decide on a leather or steel bracelet. An added bonus was doing some research and finding out the Elgin connection and the movement is a PUW 1563T which is German I am pretty sure and probably why it doesn't say Swiss made on the dial. This movement is supposed to have a hack feature and quickset date by pushing the crown. But neither of those complications seem to be working. Not sure if the stem is cut too short because there is no gap for the crown to move. Either way at some point will need to be serviced and check the keyless works to find out what is going on with the quickset and hack of the sweep second hand.
    • On the link that I posted, one of the watches has no crown and another has a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken, and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
