Hi All, Hope you are all welland safe,
I have bought a few movements to get me started now and a few tools.My lathe i purchased was a Lanco , not the best though it will get me started. The accessories that come with are still being sought out as some do not fit and finding information is vague,
I have been busy for awhile, I am asking if it is possible to ask where it is best to get spares for 1570 cal and where can i get a listed parts breakdown diagram. Hard asking about parts when you are not even sure of the name. Any help would be appreciated.
I apologise if this is not allowed as some companies or people can be put about recommendations that are not to their interest or favour.
Thanks phuckaduck
How do you know that there are parts to be replaced in first place?
Hello and thanks for asking . getting them apart is not to hard. I already have it stripped 90 percent . Just having trouble with the stem andpinion if that is right.the brass wheelsare all right but any metal has decayed so I need to look for parts
 I will have pictures next run if I can manage this compuer stuff. this is harder than stipping awatch
On 10/27/2017 at 6:04 AM, clockboy said:
You really have jumped into the deep end with a Rolex. Getting genuine spares is difficult and always expensive. Parts for a vintage Rolex such as the 1570 will be almost impossible. However I have posted a couple Rolex docs.
Rolex service.pdave other
Rolex 1570.pdf
Hi Clockboy, here are some photoes for your viewing pleasure,I do have other photoes but they have disappeared into the computersomewhere space,once i find them i will send them on if you are interested.
I removed the movt after much tinkering and molestering as parts were completely rusted solid . Movt/case holding screw needed drilling and gentle persuation, watch face holding screw needed drilling on one ,winding stem had to be broken .
The setting lever mechanism is totally gone plus some wheels
i was looking at the breakdown doc and it says that the1530 is the base for the 1570,did i read this correctly and this means i need to look for parts on a 1530 as well?
Thankyou muchly for the help and if you are interested in further aiding me in the right direction I would be greatly appreciative of the assistance . I was going to scrap the the watch but my fisrt rolex so i will see this through, bye for now Phuckaduck .
also i did say my name a few times while stripping it.
Looks like it has had some water ingress and it looks like the movement is dirty but overall it is not to bad. The hairspring also looks good so I would say looking at the pics it looks serviceable. The only issue will be is if when disassembling you find a part that needs replacing. The part/s will be very difficult to find
I recently asked a watchmaker for advice re an Omega. 552 movement. 1966 I believe. It was botched up some years ago and never kept time. I put it on my 1900 Timegrapher which all but condemned it. Gain was erratic 110 t0 230 Sec`s daily. I cleaned the balance, set the beat but it varied greatly due to worn staff etc. in 3 positions. This "watchmaker" was off hand to me and condemned all amateurs whom he  said messed up everything they touched or similar words.  As the movement is worn I will try to fit an ETA or Asian movt: to get it going properly. Otherwise it will go in the case to be forgotten about. Won`t be long before it is all Chinese anyway. They make lots for the Swiss watch industry already and they are getting very good at it. Parnis being an example. Just my opinion.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
