What type stone is this?
jdrichard
Looks like a hard Arkansas to me. Hard Arkansas stone is a form of Novaculite which is a microcrystaline quartz.
It is an excellent natural whet stone and is used for the final touching up on your gravers (assuming HSS, not sure how it would perform on tungsten).
I used it to reduce the staff pivot size and it did a great job polishing the pivot. Of course i will not know until i finish the other half and install the balance, hairspring and roller. I may jacot the final staff and use my burnishing tool.
Replied above
Thats an Arkansas stone. I had a block for tidying screw driver blades and gravers, one like yours for pivot work and a long triangle shape also for pivot work. Just add a spot of oil for best resaults. They will work on tungsten.
Hey, thanks. It does a great job reducing the pivot size.
  • 3 months later...
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
