hi. can any body tell me how to remove a caseback from a rectangular watch (Boss HB 22.1.14.2008/1.526.804)i need to replace the glass. i cannot seem to find a recess for a knife etc as the lugs are as one with the case and there is no room to play with.thanks B.
Probably. There are already scratches there. [emoji4]
Sometimes I have to use a single edge razor blade with a metal backing to start some of those off. There is also a nifty little black tool on the bay that resembles a little crowbar that you can get from China and they work great as long as you keep the edge sharp. They provide the much needed leverage that a screwdriver tip just won’t give you and you don’t have to worry about a screwdriver blade being stuck in your hand or finger. Painful experience.
Sent from my iPad using Tapatalk Pro
thanks guys.sorted it.took the broken glass out and then pushed through the dial and the back came away easily,although i would probably need one of the tools suggested for next time!(battery change etc).tried to get it off earlier near the crown but sadly the stem broke at the point where it goes into the crown (boss).so i now have the problem of trying to get that bit of the stem out.fitting a new stem wont be a problem?
i don't think you'll be able to remove that piece, and will need a new crown. And since you need a  specific replacement cystal also , that may be a bit too much to make the repair worth on on a quartz fashion watch.
  • 4 weeks later...
    • Hello everyone, I have a little problem with my watch which has a Miyota 6m17 gmt movement. I wanted to know, apart from dismantling it and replacing it, if there is a mechanical movement of the same size that would be compatible (same diameter of the movement and hands)? thank you in advance for your help.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
