Lemania S27 part question
Chopin
What is the name of this kind of part and where could I find one ? Would it be interchangeable with other movements/brands ? I feel like I've seen this before on other movements but I'm not sure. (pic off the net)
Mine has sadly broken at some point and someone tried welding it together but didn't do a very good job...
lemania-gilt-steel-vintage-watch-movement-s27-510x600.jpg.99d3fccba84d0aab320442425cf99d90.jpg
I think I read something about an Omega as well but I don't think I've found an identical part for that but I could be wrong. Indeed some Tissots seem to have this type of part but I wonder whether the dimensions are similar.
Tissot 27-2. There might be others that have it as well. As far as I know Lemania made some movements which served as basis for other well know brands.
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQr5XUhgjGRfg-8aPhystxQ9NCKgLd2xP2OGMT22db1R2FwGF26
1 hour ago, rogart63 said:
Check with urdelar.se i think he could help you find one. I found some movements with tension spring that  had no jewel. All of them had wear straight thru the metal.
I actually came across this by browsing the web and it seems to be the same part but my movement is not on that list (it was also called Lemania 2990 if memory serves me right) and I don't know if it has the same dimensions.
Do you know if I can contact the website owner and ask him to check the part or some dimensions ? I could also look up the part number but I don't know if Lemania has any schematics or lists with the numbers of their components.
http://www.urdelar.se/Lemania 3050, Friction spring for sweep second pinion, no: 7185?filter_name=spring&page=7
No problem . Just send an Email to Mikael and i am sure he will help you. He is a great guy.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
    • After a 3-week work fiasco that took up 137% of my time, I was finally able to get back to restoring a G. Boley 8mm lathe I picked up on eBay. I still need to do a bit of polishing on the tailstock but it works very nicely. Before and after pictures below. In any case, when I was reassembling the motor I wasn't quite sure which side the pully attached to, or if it matters. My question is ... does it matter? The listing photo below shows it the reverse of how I have it now, but it seemed that the cord and the reversing lever(s) should be on the right away from the belt.
    • Thanks Richard.  That’s clear.   So - another question - how much latitude is there in barrel and spring sizing? Say I have have measured the ID of my barrel to be 9mm and (all other mainspring specs being equal), the closest match I can find for a replacement mainspring is listed with an 8.5mm barrel size, is it acceptable to fit the smaller spring in to the slightly larger barrel without compromising anything functionally?  I’m in this situation now with an AS 1686 which has a 9mm barrel, but the closest replacement I can find has an 8.5mm diameter listed in its specs.  I can find an alternative 9mm spring, but would have to accept a different thickness.  I’m unsure how much wriggle room is acceptable, or whether in mainspring sizing, there’s a priority - ie thickness over barrel size etc. Thanks again for any info.  Cheers, John
    • We already have a Facebook group run by Mark , so this is a bit moot. Search for “Watch repair lessons” group.   Tom
