Watch dial removal!
bosstaki
Hi guys, I’m looking for ideas about removing the dial from this Armani watch, it won’t come out from the back as there’s a shoulder inside the watch case stopping it, I’m looking to remove it from the front side! I’ve removed the outside beveled gold ring & I still can’t see any way of removing the glass? Is the glass retaining ring press on or screwed down, there looks like there’s a chapter ring under the glass to! I’m open for ideas guys! Cheers
Can you post a picture of the movement and case ? If the movement and dial came out from the front (a front loader watch) then the glass should have been acrylic crystal as those can be removed with a special claw tool.
I'm assuming that this is mineral glass or sapphire so I think it comes out from the back...
It’s deffo a flat mineral glass with a small bevel on the edge!
cd7da47fb394a90b855443f379cd5a25.jpgb1454511b14f8636264ed1a824f7df4a.jpgabdeb400a3ae4944622d68ef62e74926.jpg
It’s a Ronda 1069 two jewel movement!
Sometimes -- though I'm not totally convinced now is one of those times -- it is necessary to remove the winder, replace the case back and compress air in through the case tube where the winder was, the internal pressure of air then pushes the glass out, which sometimes can be kind of violent at times. Usually, a large syringe (minus the needle) is used for this, there are other means though.
Just to get this straight. If you remove the crown, are you not able to remove the movement and dial through the back ?
Hi there, no mate, if I take the crown out the watch the dial will still not come out! I can take the movement off the watch dial, there’s a shoulder inside the watch case which is stopping me from removing the dial, the watch dial is larger, that why I’m thinking it been put in from the front!
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
    • I can take pictures when I am home of what it looks like.  They will be phone picture as I don't have a camera in my microscope yet but I should be able to take a few views to give a good idea of the damage.
    • One I have and it's a French Strike on a bell with Garnish worth around £1,000. I'll take a photo of it tomorrow so you can see it.
    • When you are having fun restoring false economy exits via a window. Your time and money dont always matter Col , what does matter is that you breathed new life into something that was dead and destined for a scrap heap. That has to feel good doesn't it ? Some of my favourite watches to wear are my first attempts at repair. With a face that only its repairer can love , Rolexes pah !!! give me a Smiths pin pallet any day of the week.
    • Hi, I'm Ciaran from Manchester. I've have been teaching myself watch repair since January. Funnily enough it started with me replacing straps when I was laid up with a knee injury. It grew from there after coming across the YouTube channels Watch Repair Tutorials, Chronoglide, and that of this forum's owner.  My first proper repair job was disassembling and reassembling an ETA 955.112 (with the help of a video by Mark and a walkthrough from this forum.  Since then I've completed a few services of ST36s, as well as a truly battered AS 340 which had more things wrong with it than it did right.  I'm currently working on a pocket watch from WW2 - which I'll be attempting to fit a new balance staff to. As well as a Tissot 781-1.  For those of you on Instagram I'm there also: https://www.instagram.com/ciaranwatchrepair?igsh=MWZ3bHNmdDUzdGhqbQ== Happy to have found another place to talk watch repair
