Hi guys anyone replaced the crystal on a citizen promaster? Where could I source one or a sapphire equivalent?
No need to replace, you can easily polish the original. Use the search box top right.
Sapphire for divers that are not popular can't be found, because they are thicker than the generic available, or are beveled, etc.
1 hour ago, rogart63 said:
Check crystaltimes out. They could have a sapphire replacement.
Nope, they stock for only one vintage Citizen. Having the exact sizes one could do a better search.
 NY0054 is the reference of this.
Thanks for the info the scratches are too deep to polish out I tried with polywatch and a diamond paste so I removed the crystal and its 27.71mm wide and 2mm thick I found some generic crystals at 27.5mm and 2mm thick and a sapphire same dimensions. Do you think I should go for 28mm wide? The crystal gasket looks fine.
If you have an accurate caliper i would go for a 27.8 .  But your way of measuring is not perfect . You could very well be measuring at a place where it's smaller .  I think this method is safer.
You will need the exact size, 28.70. To polish  deep scratches, first use 600 grit wet paper, in form of a 5cm disc on a rotary tool. Then move to 1000 oor 1500, and finish with diamond paste. Polywatch has no use on glass crystals.
  • 3 months later...
On 13.9.2017 at 8:00 PM, Airoh108 said:
Result on the crystal replacement thanks for all your info guys pleased with the result
Hello,
I own the same watch since some days and the crystal is slightly scratched, so I would like to replace it. May I ask which crystal you finally used?
Which diameter is the correct one (above I can find 27.71 27.8 and 28.7)?
Maybe you even have an article number for a matching crystal
Thank you
Stefan
Hello,
Thank you
Stefan
Hi Stefan,
Will let you know later when I get home.
Thanks for your answer. That already helps a lot to get an overview over available crystals.
That means, you replaced the domed crystal with a flat one. How did that change the look of the watch?
I think I would rather like to keep the original look of the watch.
It seems like I have to remove the crystal to see which thickness it has (middle, corner).
There are two Sternkreuz versions that might match the original:
MDH 278 (domed 2mm)
XMF/O 278.744 (domed with flat bottom 1.6mm - 3.2mm)
Thanks
Stefan
For that purpose the best is polishing the original crystal. No need to remove it from the case. Many threads about that.
MDH 278 (domed 2mm)
Thanks
Stefan
I love the look of mine the flat crystal makes the dial pop more but I haven't tried your suggestions. Let us know how it goes. Fantastic watches I have 3 now. Enjoy
You are right, this looks better than expected.
Nevertheless I think I will go with a domed crystal. Will keep you informed and add some pictures.
Polishing the crystal doesn't seem an option to me, especially because a new crystal is available for under 10 €.
Here is the promised feedback.
As planned, I used a XMF/O Sternkreuz 278.744. I'm happy with the result.
The comparison picture shows the new crystal on the left vs. the original on the right hand side.
You can see that the border of the replacement is a lot thinner than the original, in the center the height is comparable. If I would really like to use the watch for diving, I would't be very confident concerning the stability against water pressure. For swimming and normal use it should be sufficient.
The other two pictures show the watch before and after switching the crystal.
Thank you for your input.
Very nice looks great
    • He's trying to tell you something like this isn't really a good plan. Just a reminder of something when they quote something from the other page when I looked up your serial numbers Estimated Production Year:    1937 Run Quantity:    4,000     Grade/Model Run:    310 of 329 Estimated Production Year:    1917   Run Quantity:    2,000     Grade/Model Run:    127 of 329 You will note that one of your watches was a batch of 2000 made in 1917 and the other was a batch of 4000 made in 1937. Then did you notice how the main plate has a serial number the complete serial number? Then all the rest of the bridges have a partial of that serial number and typically the serial number is also scribed on the balance wheel. The problem with manufacturing when these watches were made was that there were variations as you can see the balance bridges do not interchange because they're not of the same batch. Basically what happens is the main plate is made the bridges are made there assembled together and then the holes for the wheels the jewels etc. are done when everything is assembled as this is the only way they have to get all of the alignments absolutely perfect. Then each of the escapement's and balance wheels are adjusted for each watch.
    • I've never been able to find any information on jewel sizes.
    • I had thought about doing that. Is there a concern that if I can't get the crown off that the water from rust remover and penetrating oil might get trapped within the crown/stem assembly?
    • Hi, Does anyone know if there is any kind of dimensional reference for the Seiko jewels used in their movements? Specifically I would like to know the dimensions of Seiko part 011307 that I am not able to source. The jewel is found in the 27 jewel 4006 movement as well as some other obscure Seiko movements.
    • Finally I have the watch running at approximately -5 SPY off wrist approx 15 degrees and approximately +5 SPY on wrist. I did try adjusting it over a larger temperature range of +5 degrees up to on wrist temperature without success. I could adjust well at both 5 degrees and wrist temperature but I then found that there was a significant loss of approx 20 SPY at mid temperature of around 20 degrees.
