Seiko 5m62-0bl0 case parts
Does anyone know where i might get a diagram with the part no's for a Seiko 5m62-0bl0 case ,or the actual part?
i need the pendant tube insert not the crown seal but the insert that the seal then sits on , have asked over on SCWF and RLT , thought i'd try here to as not having a lot of luck so far.
Thanks guys
Edited by Andyclient
Thanks guys
I would measure & try Cousins who have really good selection of tubes.
Thanks CB but it's not the actual pendant tube its a nylon/plastic insert that fits into the pendant tube and holds the seal , I thought the crown gasket i ordered from Cousins would be the replacement but alas that was just the seal o ring.
I'm fabricating one from a biro refill at the moment but if i could get a case diagram i would hopefully be able to get the correct part
regards
Andy
38 minutes ago, ro63rto said:
You didn't say it was the nylon part on the other forum
Is this it?
Sent from my Honor 5c
Thats it brilliant , thanks so much ,most appreciated
32 minutes ago, rogart63 said:
If so that is the same as in some 7546 watches. Like the grey part that sits outside the gasket. Have one of those if you like?
Excellent thanks very much indeed, if you let me know how much and i can paypal you.
Thanks so much guys great help
Did find it but it's not in super condition. Maybe i can find some other one  It has a small mark because the thread for the crown was damaged.
Thanks Rogart , I did have a look on Cousins but they are out of stock till the end of Sept
  • 4 weeks later...
16 hours ago, rogart63 said:
Hi Andy
Found one plastic gasket part for you. Send it tomorrow. Free of charge this time. found it in a 6423-5030 case. According to jules borel it has the same seiko number. It.s about 2,5 mm and 1,4 mm long
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_CS^6423-5030
Thanks Roger thats fantastic , very kind of you ,and most appreciated
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
