Citizen 6031 Movement Question
PJA
Hello there. My wife has an old Citizen 6031 watch which probably hasn't been used for at least 10 years (was belong to her late father) and after changing battery and not getting any reaction I've taken it to a repair and the gentleman basically put a drop of some liquid on it which made it works for about 5 minutes and then stopped working again. My question is could it be that the oil dried after many years of not working or how to go about trying fixing it? I have ordered a new equivalent movement which I am waiting for, but for my practice I just wanted to try to fix it even though it doesn't pay. Thank you for your assistance.
Quartz movements can and certainly should be serviced just like mechanical ones. But we're usually talking about quartz movements that were made to be serviceable (so not the cheap chinese plastic ones...).
I would say that this one can be serviceable and you could certainly give it a try. I find them a lot more simple than most mechanicals.
Only wish they were larger in size as it's a fiddly job.
This type of movement could also require short circuiting it to start.
Thank you.
2 hours ago, Latvas said:
Have you tried line release cleaning
No, I haven't. I am just starting now with this hobby and not even know where to start, but can you give me a few words about how to go about it? I was trying to search it and can't find anything about it. Thank you.
Most quartz watch testers have this function. It creates a spinning magnetic field that drives the watch mechanism at speed. This can be enough to break loose old crusty oil or slight corrosion and get the watch running.
It's a bit quick and dirty as watch repairs go but can be very effective especially if the watch has been sitting unused.
Neil
7 hours ago, Latvas said:
go to ebay, and search for , quartz line release.
Line release is a novel way to release a gummed up quartz movement. However it does not offer a long term fix. I would relace the movement.
12 hours ago, Latvas said:
I was searching for line release tools and correct me if I'm wrong, as I see it only the Horotec Turbo spins the dials while the others do only battery check like with multimeter without opening the back case?
  • 6 months later...
  • Similar Content
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
