Less than perfect tools
skridlov
I know that one should only buy the best. How many amateurs do, at least initially?
Here are a couple of beefs about the tools I'm currently using:
Movement holders. I had a half-useful plastic job whose metal bolt ran through a hole bearing plastic threads; do I need to say more? The alloy ones I'm currently using have the infuriating habit of suddenly ejecting the movement when pressure is applied to a screw; I've yet to completely destroy a movement on this account but it surely must be only a matter of time.
Demagnetiser. I guess like hundreds of people I have one of the "blue boxes" emanating from smoggy Shenzen. Sort of works, some of the time on some watches/movements. But often (very often) no amount of use will eliminate the magnetisation completely.
Hand broaching vice. I only obtained one of these this week. A chromed version which costs £10 and is widely available. The first one arrived and was immediately, obviously, entirely useless. The two discs with holes that line up (theoretically) don't line up. By the time you get to the smallest (most useful) sizes the holes are 50% out of congruence and 100% useless. I mailed the supplier - a well known UK company with an interest in poultry - with a snap and a mild complaint. They sent me another one, which had been "checked". It's still useless, only slightly less so.
Speaking of "useless", incessant attempts to delete an accidentally uploaded snap have proved fruitless.The forum constantly reverts to the previously inserted text and snaps - even if you leave and return. Ignore that which isn't of the broaching vice.
Roy
Edited by skridlov
extreme irritation... 27 seconds elapse...
Yeah, I've noticed the problem of being unable to delete an uploaded picture.  Fortunate for me (and all viewers I suppose) I've only accidentally uploaded the wrong watch movement image and and never a pic from my "Cooking while naked" album.  :blink:
I would say about a third of my tools are cheap knock-offs and the rest either vintage Swiss or new Swiss.  With watchmaking the tolerances are so small the knock-off will almost never do, but with budgets being what they are, sometimes you just have to make do. The tools that perform poorly help me develop better skills to work around their deficiencies though.  Sadly I've also needed to develop new curse words on occasion as well.
Experience has educated me to only use cheap Chinese or Indian etc..tools for work that requires no manipulation or application . Why pay £50 for a Bergeon movement cushion when you can buy a non branded one for £5.
If you're looking for a decent demagetiser I can thoroughly recommend the Elma demagetiser. Not cheap but worth every penny.
Regarding expensive quality tools. The cost is not that great when considering the potential to recover a great deal of your original investment on the "Used Market"
Some people will argue that you can modify cheap tools to be satisfactory but until you own and use a pair of Dumont tweezers, you can't appreciate not only the functional but the tactile beauty of quality.
As for brands I'm happy to recommend Bergeon, Horotec and similar
Sent from my SM-T585 using Tapatalk
I have a cheap plastic Chinese movement holder and a cheap Chinese demagnetizer. Both of them work very well for the limited type of work I'm able to do. I change batteries, oil pivots I can see from the outside,  replace dials and hands, recase movements, resize metal bracelets, and that's about it. I don't mess with hairsprings. I've destroyed a couple trying to get them back in shape. I don't disassemble anything unless it's already broken and what happens doesn't matter.
I've had a fair amount of success is dismantling, cleaning, re-assembling and lubricating so far (I have only once removed the balance cock and it didn't turn out well.) In most cases I remove the barrel bridge etc and the keyless work (a less archaic term wouldn't hurt, IMHO) and immerse the parts in Elma Pro for a while, and then a 180 sec ultrasonic treatment and a couple of rinses with Iso-P. Luckily I have a lot of stuff to practice on and mostly it's not a disaster if the outcome is negative. Even though I've only once done a full dis-assembly and usually clean the movement with the balance assembly and train in situ (apologies; I can almost hear the groans), I don't recall having any problem directly associated with this approach. But how to lubricate the upper balance pivot? I am starting to realise that you gets wot you pays for - in this discipline as well as every other I've encountered. I'd certainly like some good tweezers!
I'm currently working on a hunter and the difficulty of getting the hands set (I re-lumed them) and the crystal fitted without collisions occurring is not to be understated. I broke the incredibly thin V. low dome crystal despite immense care trying to refit the bezel. This is the second time I've had this problem with a hunter.
I also regularly encounter problems with the KW (see above). These sub-systems always seem so crudely designed.
I have a beautiful Omega 1906/7 half-hunter here that lacks a setting lever and stem. The stem may just exist in the parts skip. It runs like brand new with a sparkling gilt movement (only 15j unfortunately). Anyone here make parts like this?
Roy
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
