Hello All,
I'm looking for a little insight from experience.  I've got a Valjoux 71 movement that I'm working on which has poor amplitude.  The mainspring looks fine (although a replacement will be in shortly) and I haven't found issues with he pivots or jewels yet.  The drum seems okay in it's bushings too.  The center wheel has quite a bit of play in my opinion though.  I've attached a vid from under the microscope as evidence.  Anyone with more knowledge on the subject (or experience) please chime in!   For the rest of us newbies, we can just take a vote- too much side shake?  Yes or No?
Thanks!
M20170616_006.mp4
Edited by RyMoeller
Remove duplicate link
Thanks for the input @clockboy, I thought it was pretty bad but appreciate the confirmation.
There is no center jewel for this movement.  I'll pull the center wheel and take a look at it though.  I'll see if I can get some good pictures of the hole too.
I think I see a repair by Mark where he fitted a jewel to support the centre wheel.
That will be helpful as it looks like I may have to go that route too.
Interestingly the hold doesn't really look worn- as you can see from the image attached the silver plating hasn't even worn off yet.
The center wheel looks okay too.  Strange how the fit is so poor.
Is it the original center wheel, or was it replaced by someone with something that was close to fitting?
That did occur to me.  I've spent the afternoon trying to track down an affordable replacement as opposed to modifying the plate (by adding a jewel or bushing).  There are a couple of other issues that suggest a less than stellar repair (one of the chronograph eccentrics has been glued into the top plate).
Hi Ry,
Cousins has a centre wheel but it's £26.
I can't play your video on an iPad, so can't comment on the fit.
S
No luck with Cousins I'm afraid.  They've got the chronograph runner (8000) but not the large center wheel (206).  I've got a few other places to check but thus far the only option is pretty expensive- $74 USD!
I have just looked at the video and that is bad. If you decide to fit a jewel or a brass bush be careful when you to pushing the cannon pinion back on, you could push the jewel or bush out. The hole in the plate has some nasty scoring which looks as if at some point a hard piece of dirt has been stuck in the hole and has been rotating. The steel that the wheel has been made of is much harder then the bottom plate.
D'oh, sorry, brain not engaged.
Jules Borel lists a Valjoux 71 and a 71GHH; they list a stock number for part 206 against the GHH and a price of $14.30, but the stock code comes back as "no items found". Not sure what this means as I normally encounter in stock or out of stock. May be worth calling them.
At $72, it sounds like a brass bush would be a good option. I would be inclined to solder it in place to prevent the problem Oldhippy describes
Ah thanks for the tip regarding the cannon pinion and a replacement jewel.  That's a headache I'd sure like to avoid!
I agree, it looks like a jewel or bushing is the way to go at this point.
The only way to avoid a repair is to obtain a new bottom plate.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
