Waltham Pocket Watch
For some reason - I don't know why - my Waltham won't wind. I'm thinking the mainspring is unattached from the barrel wall or the arbour somehow because I can get it to work for a while but then it stops. I don't think it's broken.
I'd take it apart but that's not so easy either.
And, here, I thought I knew everything there was to know about watches...
It's a Waltham Hunter Gold filled watch. I've taken out the case screws but it won't drop out and I don't think it's a drop-down style watch.
Someone has obviously tried to pry it open in the past because there is evidence of that.
Just turn the two case screws so  they are both away from the case, pull stem to set the hands, make sure the bezel is off and the front is open and push lightly away from the stem and the movement should ease out, you could take out the balance if you think you might damage it.
There is a small indentation and opening where the barrel wheel is and also a small hole in the plate that appears to have some sort of push lever in it. Perhaps this is where the click can be released.
I think you could be right.
I also found this.
Some will have a little hole in the side of the movement that you poke and that will let the spring down.
I also found this.
OK, then that is probably the method to let down the spring on this watch.
The opening just goes through to the barrel and there is nothing in there to push.
I wondering if I have to take the barrel plate off to get to the click. Nothing should explode since all the other wheels in the train are under a separate plate.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
