Daily Watches
RayCJ
Yes, I know...  These are not the fanciest timepieces in the world but, I'm very happy with them. Every day, I select the one that best matches my work attire.  I tend to wear the black one in the evenings and on weekends.  They are all the same model of Seiko 5 (7S26C movement) in different colors.  They are dressed up just a bit with different bands obtained on Amazon from Hadley Roma (cloth leather) or iStrap (cowhide).  The iStrap versions have a nice deployment clasp.   Perhaps you've seen from one of my other posts, I purchased a timegrapher and regulated these.  They are all keeping time to a few seconds per day -well within 10s.  Two of them are essentially dead-on within 1-2 s/day.  Just about each one needed a slightly different method of regulation.
I've done a good bit of metal-work over the years but nothing artistic or related to jewelry. My goal is to remove the ring around the crystal on some of these and modify it somehow... -perhaps bright-polish them or hand engrave a simple pattern.  Another thought is to machine a ring groove and insert a corresponding bronze fitting.  I have sufficient equipment to modify these any way I wish -or make an entirely new case if I wanted to.  The real problem is that the artistic part of my brain insists that I hold my crayons with a closed fist.  We shall see...  It's just a thought for now.
Ray
Go for it!
One thing I've wanted  to do with my SNK809 is replace the flat mineral crystal with a CT063 domed sapphire one from Crystal TImes. I think it would give it a more vintage look.
And hey, if you can pull off engraving, you can always find inspiration in the engraving styes found on vintage watch bezels!
I would like to see what you are refering  to in what you say is a ring groove and bronze insert .  That takes some skills and tools that I don't have .
I like dadistic's idea of the domed sapphire crystal . I have several seiko divers I have fitted withe the double domed , blue tint crystals from Crystal Times and I like the look , and get compliments on them as well as install them on other peoples watches .
I think that Crystal times has a gallery displaying customers watches including some of mine .
Wow...  Thanks (Dadistic and Ricardo) for letting me know about Crystaltimes.  I had no idea such replacements were available.
I'll have to read-up about what double-domed means... I presume its concave or convex on both sides.   I noticed some of the replacements have optical coatings.  Wow, if it looks the way I envision it, that would really add a nice touch.
Ricardo... I have a full machine shop.  My father was a tool and die maker and my uncle was a metallurgist.  I was born/raised in their shop and worked as a machinist then, tool-die maker until the early 80's.  I've maintained an active role in metalworking and at one point, was semi-retired and ran a small business doing prototype development for medical devices as well as one-off fabrications for a friend who owns a large marina repair shop.
I've never taken one of my watches apart to see how the crystal is held in place.  I presume the tapered ring around the crystal can be removed.  I could modify or re-make a part like that with relative ease.  I could make it on manual equipment or I could have a CNC machine cut one out.  For a one-off piece, it would be easier to make on manual equipment.  Anyhow, some kind of a border made of a contrasting material around (or within) that tapered ring would look nice.  I can envision something inlayed or possible sweated or press-fit into place.
It would also be nice to engrave a simple design in that ring.  I've done a great deal of work with precision files but never with an artistic flair.   That will be a first and I suspect I'll need to make a few replacement rings if I decide to try my hand at this...
Ray
9 hours ago, frenchie said:
Very nice collection Ray, thanks for sharing it!
Looking forward to seeing your metal work! :)
Thanks for the encouragement!
I think I have an idea for a simple mod on the bezel.  Right now, I'm pondering the replacement crystals and if they should be AR color coated and if so, which colors would look better on each of the above watches.   The options are blue, purple, green and none at all.  I can visualize this style of coating but don't know how subtle or pronounced it is on these particular crystals.  It would be nice if they offered a general color correction, the same as what is available for eyeglass lenses.
Feel free to shout-out your suggestions.
Anyhow, I'm not planning on working on the bezel until the crystals are ordered and arrive.  (This way, I can screw the whole thing up all at one time :wacko:).
Ray
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
