Finally got a Seiko 7a38
ro63rto
Winging its way right now.
It's a non runner from Hong Kong and the bezel looks a little faded but should be a fun project.
Besides, if it is beyond my rather basic skills, I know a man in Berlin that can revive it.
Seiko 7a38-702a
Next will be the 7020 version Geo likes [emoji106]
Sent from my Honor 5c
     I have my share of 7xxx and other battery powered Seiko Chronos , but the 7A38 is my favorite .
In the past I have had about a 50% success rate in repairing them , but these can be a pistol to work on ,....mostly because if the circuit board is kaput , that's it .  I don't have the patience to work with the plastic gears mostly because of the fragile pivots , so I had a large stash of parts I sent to George C . where they will do the most good .
Good Luck with your incoming 7A38 .     BTW , The watch forum , 7A38 - by the numbers  , is a good source of info on this caliber .
http://seiko7a38.com/
Nice collection you have there.
I too have a few 7t watches.
7t34
7t62 asymmetric
I have a few others but Photobucket is playing silly monkeys and not letting me access all my pics.
This is my first 7a and hopefully not my last. I just refuse to pay the inflated prices some of them are going for so I buy cheap non working ones and keep buying until I can make one good one. Then I send them to George  when I fail or chicken out
  • 4 weeks later...
Well, bad news and good news.
The bad
But the good news is a VERY generous member on another forum sent me a working donor.
Only thing is.... I stuck it on a brown leather strap with gold buckle and can't bring myself to pull the movement to transplant into the first one [emoji4]
Now all I need is a working donor with a trashed case [emoji6]
That IS bad news and Very good news , and a little something in-between....I think .
Curious , Is the dial seated properly?  In the pic It seems to be lifted a bit from 10 to 3 . I have had similar circumstances where the dial wasn't seated all the way caused by the dial feet not being all the way down . I loosened the dial foot screw and was able to better seat the dial....sometimes .
Never noticed but I'll take a closer look. Might just be the angle and that shadow but we'll see.
OK , more good news..... Looks like you may have to zero out the minute subdial .
For that, it will need a case clean and rebuild with gaskets first. Will be ordering a load soon for this and 6 or 7 other watches.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
