Hi every one i've been buying a few books about watches , history of the different companies, movements and how they got to the fine tuning but i was wondering if any of you can suggest dedicated "manuals" for the individuals makes or movements.
With cars there are well detailed instruction, CD with plans and diagrams for tolerances or oils\greas to be used recommended by the manufacturer, codes for replacements and standard maintenance bits and bobs .. i was wondering is there such a thing in the watch world?
Not all movements, but a lot of them have parts / service sheets.
If you go to Cousins UK download section they have lots that can be downloaded.
https://www.cousinsuk.com/document/department/watch-movements
Some are nothing more than a sheet with pictures of parts with their part numbers, but others can give oiling information or dimensions.
In general there isn't a brand repair manual with some notable exceptions like Bulova Accutrons
A good range of books to look out for are the " Esembl-o-graf" chronograph manuals they where produced in the 1940's so deal with mainly pre war chronograph movements they are the nearest thing to a Haynes car manual for watches they give step by step servicing instructions and oiling guides they are clearly illustrated and identify each part as you come to them they can be found on ebay.
Although it is not specific to any brand of watch a lot of us buy "Practical Watch Repairing by Donald de Carle".  Although it is an old publication, a lot of members work on older watches and find it contemporaneous, a lot of the guidance is still relevant for newer watches as well.
Watch Repair for Beginners by Harlod C. Kelly is also worth having.  Lastly the Cooksey Shugart books - Complete Prtice Guide to Watches is also useful and is updated yearly, there is quite a bit of info given especially for American types but Swiss and others are also covered.  If you are starting out you may find these worth having.
Cheers,
Vic
Hi @Andrewolf79 and welcome to the forum.
I recently acquired a copy of the U.S. Army Ordinance Maintenance manual for issued clocks, pocket watches and wrist watches (aka TM 9-1575 c.1945).  A digital copy can be viewed here:
https://archive.org/details/TM9-1575
It's very organized and is full off definitions, tool indexes and illustrations of various sub-assemblies, etc. While make/model specific, I found it very helpful in learning basic concepts and procedures. The tool lists are very comprehensive as well.
Hope this helps,
C
  • Similar Content
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
