Can you please advise a method to increase a minute hand diameter?
Diameter: 0.48mm
I need increase to 0.65mm to fit a new movement
thank you
Hi,
you should try using a staking tool. I haven't done it myself but you can do both enlarge and decrease size depending on which punch you use.
For enlarging only y wonder if you could use a sizer pin, problem would be deforming hand.
Please let let us know how it works out.
Use a reamer but be careful not to bend the hand, I would put a tiny amount of oil on the reamer to help the cut. I can see from underneath the hand it has a shoulder make sure you don't remove all of the shoulder for the fit you need because the hand will be ruined and won't fit correctly.
I agree with
I agree use a reamer also there is a tool for holding the hand see below.
58c110785b1c3_ScreenShot2017-03-09at07_40_56.png.a8b57907b1503800be613e4308157ea9.png
there are several tools to hold a hand while it is reamed.  the reamer is easier than a staking assembly.  a set of reamers is a good investment.
Thank you very much everyone. It is very helpful.
I made it.however the shoulder is almost gone.
I drilled to 0.6mm frist and then enlarge with sizer pin to 0.65.
Thank you so much.
I agree with
Is the Indian version of this okay?
I have had mixed experiences with Indian tools.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
