I don't necessarily understand what you mean but I'll give it a go.
Magnetism of items is not necessarily a bad thing, it just depends on how and what you use them for.
If we're talking about watchmaking then you don't want magnetism on screwdrivers and tweezers because that can affect the magnetic components of the watch and it might even make various components magnetic, such as screws.
Jewels and rubis are the same thing. Just different names for it.
the reason i have asked and thankyou for your response is that when i am trying to get the screws in to the setting , ifind that the slight of magnetism helps with the screw not flipping of , the down side is that the smaller the part then it has atendency to try and stay with the tool , that was why i was trying find out if it is abad thing
That would be the upside of magnetism I guess but I'm not sure if watchmakers usually use magnetized screwdrivers on their watches. I certainly don't.
I am curious to find out if others use magnetized blades on their screws...
Magnetism is not desirable on your driver blades or tweezers with particular reference to mechanical movements. It's not such an issue today with modern watches but if you introduced Magnetism to the hairspring this can cause the coils to stick together during oscillations and the watch will run abnormally fast.
Carbon steel tweezers are prone to magnetism, far more than stainless steel.
Also not all jewels are rubies some can be from other hard stone and can even be transparent.
Also magnetism, if significant enough to other parts of the movement could have an adverse effect on the moving parts with regards to friction, ie.. pushing or pulling.
Professional Watchmakers constantly de-magnetise their tools.
Sent from my SM-T585 using Tapatalk
Also I should of mentioned that when considering Rubies, these will be synthectic rubies.
This doesn't mean there fake but grown in a laboratory for a specific purpose.
Magnetism can be a nuisance and is generally undesirable around watches. The biggest issue is having a magnetised hairspring which  throws the timing of a watch into a tail spin. Generally you need to demagnetize your tools and watch parts when working on a watch. This includes tweezers, screwdrivers watch parts the movement and everything else that comes in contact with the movement. The good news is a demagnetiser can be obtained at a very low cost and they are easy to use. I like this one because, due to its small size, I can also use it to demagnetise parts that I turn in my lathe.
   Watch Repair Screwdriver Tweezers Electrical Demagnetise Demagnetizer Tools
david
Magnetism is bad for watches & clocks. Magnetising tweezers to pick up screws is a really,really bad idea you should learn to dress your tweezers & then practice handling small items with them. Hairsprings do not work being magnetised and fitting shock springs that are magnetised are impossible to fit, quartz watches do not perform or just stop if magnetised .
Thinking you mean quartz watches can stop if de-magnetise. They require opposing forces "Poles" to operate[emoji5]
You are correct Quartz watches are mostly immune, but strong fields can mess with the stepper motor.  The point I was trying to make is avoid magnetising any part of watch and purposely magnetising a screwdriver is a stupid idea.
For screws that are hard to place use your tweezers to hold it or make the screwdriver tip slightly sticky with something that won't come off on the screw. I have used Rodico putty on real short screws to hold them to the driver tip then cleaned that off with more Rodico after.  I also find "Firm" Therapeutic Putty (Silly Putty like stuff) great to have around for the same purpose.
I wonder if you could demagnetize the screws in a small ziploc bag?
Edited by sperki77
spelling error
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
