Bit of a sticky wicket that one...It appears to be a single sunk porcelain  dial from a pocket watch no? If it is, then the sub dial was soldered in place and then the dial was fired. To repair the dial can be re soldered but will the heat to do so crack or discolour the porcelain? A better option would be to use a high quality two part clear epoxy. All of this would depend on the value of the dial be it monetary or sentimental...If the dial is indeed porcelain, then the line edge would need to be addressed and sealed on the face side as well to prevent hairlines from forming. The one thing going for you is the fact it is such a clean break. Wonder how the damage happened?
Hopefully some one with dial experience will chime in...curious myself as to the best way to proceed.
Ron
94marconi
Its a shame because there are no cracks in the dial a little nick  on the outside edge that may be covered in a case. Im thinking crazy glue LOL
Edited by adiorio110
I would be more inclined towards the epoxy myself although the gel types of cyanoacrylate super glues are tempting to use for their convenience. Another concern I have heard of using modern glues is the aspect of off gassing contaminating the parts inside the watch...where are our dial experts when one needs them...
Ron
I agree with Ron on this, the 2 part epoxy would be the best choice.
Any particular brand or type ?
Is gorilla epoxy good?
Sent from my SM-G900T using Tapatalk
As Oldhippy said, shellack..... or soledering tin.
I'm pretty good at soldering if you don't think it would hurt the enamel I would try it.
Just now, adiorio110 said:
...  if you don't think it would hurt the enamel...
It won't, since enamel is melting at around 800 Celsius.
Epoxy would be my choice too. I would let it cure fully, and then let it air out for at least a week or 2 to make sure all the gases have evaporated.
With soldering, I'be afraid that the expansion of the base metal would cause the enamel to crack.
That is a good point
Quote
Looking at the video szbalogh posted  it looks like they solder it in after enameling is done. But it is a nice clean dial, I would hate to literally toast it.
Believe it or not, but I've read that some folks use Elmer's to reattach enamel subdials. Easy to try and easy to reverse.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
