Diashock: Seiko Shock Protection Advise Needed
Dear forum members,
I've acquired several Seiko watches I'm restoring. Although I haven't done so with the first movement that came out from the lot, I'd very much like to disassemble the Diashock on the plates to do a more, thorough cleaning and lube. The system used by Seiko is not as "user/tool friendly" as the several Incablock solutions out there -- I can deal with them with minimal problem - and there is not a tool I could find in my Internet search.
Has any one have any luck by assembling back this system? Is there a tool we can either buy or make? Is there a procedure for this operation?
I appreciate your input and thank you in advance for your help.
Robert
PS.
The movement is the 7S26/7S36 using the rectangular Diashock.
Hi Robert, I would have thought that two pieces of peg wood cut to a chisel shape with a small notch cut out would have let you fit them.
I always have my pegwood point at one end and chisel at the other.
Just a thought!
Edited by Geo
Thanks for the help Geo, I'll try that.
Also I'll first prepare -- with a really transparent nylon bag -- a parts catcher just in case. Those springs are anxious to run away the moment you loose them up a little. They fit in under tension. This tension bends them outwards in the center so when an end is free they just happily hop into neverland. When inserting them back it is kind of a struggle to have them acquire the proper bend to hold the jewel (another slippery critter) and fit them in the grove at the same time.
I'll post the outcome as soon as everything is in place.
Robert
:) Please do not laugh! I had a similar problem with a novodiac (clover shaped) antishock. Didn't have the money for the special tool so I used a paper clip. Meaning the outer plastic shell. It was about 1.5-2mm in diameter and had the right flexibility in it to "mold" on the spring... and surprise! I got it out. When I put it back, I just placed the spring on position, said a prayer, pushed down the plastic thingy and turn the whole movement holding in place the plastic. And there it was happy in its place.
 Of course, the oiling is done like with any-other antishock.
Good luck!
The spring is less likely to fly because you hold it down with the plastic... or I don't know, maybe I was lucky! :)
Excellent and thank you matbog, good idea. I will be testing both systems soon. I ran into some trouble...I lost the lower jewel and I'm waiting for a replacement! I will make a report on this as soon as I set up again.
Robert.
Ahh... the barsteward that is the Seiko 2 legged Diafix. The standard 3 legged versions of Diafix and Diashock work fine, however this particular one can be a real pig and is best left well alone. I have just had a problem with one resulting in a lost cap jewel and have given up and bought another movement to replace the train bridge. This system didn't really serve any purpose apart from upping the jewel count.
I was playing (that's how I call it) with a Seiko 2206A - smallest automatic movement I've handled so far. And of course my cheap tweezers snapped and the hollowed jewel flew "somewhere". After half an hour kneeing around the kitchen I decided to try a  hollowed jewel from a russian Wostok. Don't be surprised when I am telling you it worked. Not COSC obviously, but for just playing, it worked. So then I continued. And of course, it was "that day"... and the clutch wheel also flew away, somewhere behind me, with a metallic sound... After another 30 minutes of kneeing with my trusworthy cheap led flashlight... I was full of resentment. I gathered my tools, put the movement back in the cheap organizing box and left the kitchen....
But I am trying to make a point, not only make you laugh!
I returned after 30 minutes of watching tv - actually calculating trajectories and probabilities of ever finding those two  little things again, And I decided to sweep the entire kitchen. And I **BLEEP** you not: I found those two in the (small) pile of dirt.
So, my advise: Sweep your work area and cross your fingers!
Your Lower jewel didn't dissapear to the other side... it lies somewhere around you and laughs... a diabolic laugh - at least that's how I imagine it.
Thank you guys,
Blacklab: I usually don't bother with those but I figure that at some point I had to play with it. Bad idea! I ordered another movement from the bay.
matabog: LOL, You are so right, I can hear it laughing at night! It happened right after my posting here. I hope my wife has not used the vacuum in that room yet. Unluckily for me, it was the lower part of the assembly that got lost, I have the spring and the cap jewel I wonder if I could use some ETA incablock parts I got around the shop...I'll get back on this one.
Edited by bobm12
I've got a brand new Seiko crown probably down the back of my work bench sitting giggling at me. I even tried the "Buy a new one and it's sure to turn up tactic"......................but it didn't. :-(
Geo, is that the one for the chronometer? I remember one of your posts you had lost a crown. In my case, I keep a statistics. I know that I can only have 4 parts lost at one time. Once the 5th is lost one of the other 4 reappears! Of course, the count re-starts once my wife vacuums...Now, who is going to tell her not to?!
That's the one Robert.
I've lost things that are that small you would hardly feel them if they were in your eye, but always managed to find them, but not this crown.
I know the feeling, I opened a main spring barrel to service the spring and next thing I know, the spring jumped out and there I am holding the pivot, the lid on the workbench and the main housing lost propelled by the spring (the spring I found quickly). I haven't found that part yet!
I use a magnet to find lost parts. It is one of those used in the kitchen to hold knives and stuff. It has found many big and small part for me but this time it has failed to do its job.
... regarding the paper clip method of taking out and putting back a Novodiac spring... I managed last night to brake one... not the paperclip, but the Novodiac Spring. My luck was that it was only one corner out of the three, the other two appeared to be holding the jewels in place.
So, take care!
Taking these out is surprisingly easy. I use a screwdriver believe it or not.
Putting them back in is a little more tricky. My method is to place the spring in situ and then I use two pairs of tweezers to apply pressure to both sides simultaneously and then turn the spring slowly until the spring is under the lip.
I totally agree with you, I would do the same, at least this is how I did it on a Citizen 8200A. But I was referring to the Novodiac spring - it has three corners and three grooves to fill - not like Seiko which also has three corners but only one groove.
Edited by matabog
The kif tools are useful in that case. I can't remember the last time I did a seiko but I have a few scrapers I will take a look at later
Thank you guys, I will definitely try Mark's 2 tweezers method. I lost the bottom jewel trying, most people lose the spring....just my luck. I believe I can make an older model Seiko jewel work for that part. I was just giving this task a rest for more "quiet" days (mostly week ends without activities). This is probably the most trying task I've ever tried on a watch so it needs lots of time and an exceedingly peaceful environment! For the first time I won't be having my kids around to do this operation with me.  :(
I finally got around to do this spring. In brief, the lower jewel was lost at some point and it was replaced with one from another older plate (the ones with the 3 diashock lobes).
To make the story short, those jewels are interchangeable (older and newer) as long as you have the right spring which I didn't lose.
The method that works the best was Mark's with the 2 tweezers.
Not for lack of tweezers but out of laziness, I used 2 #3 tweezers I got as a promotion (free!). I also grabbed the bag where those tweezers came in -- along with other goodies (big sealable bag) -- and cut the bottom off. I used the bag as a parts catcher...and I didn't even need to catch a part!
Knowledge gained from the above: The two tweezers system works easily and perfectly!
Thank you Mark, awesome trick! Soon I'll make another watch happy!
I use a pegwood,make it a round with diameter as the jewel spring.
Make a round dimple on top of it and use it by rotating it. The pegwoods ends make the end of the springsgo under the shim
br
emso
p.s: sent from my s****y phone so sorry for typing mistakes :-)
Matabog, this works a treat mate!
I used it in my 7S26A service, and it saved a lot of hassles ... thanks heaps :jig:
After a LOT of research and reading, here's what I've found Bob ... and you are going to love it.
I saw a post with these three pics .... it's THE TOOLS for the Seiko Diashock and Trishock System!!!  Yeah baby!!
Only problem was he didn't/wouldn't say what they were.  And so the hunt begins...
Remember I've been in the IT industry for 22yrs, and have a few tricks in my bag.  So I enhanced the photo, inverted the colours, and altered the YGB of the photo of the complete tool, so that I could read the markings on the side of the holder.
It reads:
"2.00 Bergeon 30610"
It's a 2mm Bergeon Barrel Arbor Holder
Here's the picture of the boxed product
And the cheapest place to buy it is here, that I've found so far:
http://watchmakingblog.com/opencart/upload/index.php?route=product/product&product_id=475
Next were the attachments and I had nothing to go on but the pictures.
Until I came across this article ... but all it says is to file a piece of pegwood to shape  ... Arghhhhh!
BUT ... instead of Diashock or Trishock, it said KIF
BINGO!  That was the nugget I needed for a search term ... and Booya!
Buy them at Cousins in the UK
https://www.cousinsuk.com/catalog/tools/jewelling-tools-for-bergeon-kif-inca-seitz/kif-shockspring-tool
... Annnnnnnd my work here is done B)
Need links for us dummies Mark :P
BTW, any of my English Cobbers wanna buy these for me from Cousins, and send them standard Royal Post, and I'll gladly payal you the funds ... Their delivery costs are crazy!!
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
