A broken HMT Janata stem
SamR
Hi all,
I'm new here – very new. And I come to you as a simple man with no watch repair skills – I just hope you can help.
I bought an extremely cheap HMT Janata watch from an indian seller on eBay. I've done a lot of reading so I know it might be fake, and I know the face might be repainted.
589655399120d_Photo_04-02-2017_10_09_17_pm.thumb.jpg.b9305c11b32ff97cc741287b5aacf3ee.jpg58965566d6dc8_Photo_04-02-2017_10_09_50_pm.thumb.jpg.db66a21d35bc9fa26f30960b7744447c.jpg
But – the stem broke back in November. I took it to a local repair place and it took them roughly two months and five visits from me to tell me they have no idea what it is and the movement is 'something probably indian'.
It took me about ten mins to find the following info – so I thought I'd like to check them with the geniuses here.
IF (a big if) it's real, it looks like it's this movement: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&HMT_0231
Which is 'basically' this: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Citizen_1802&
Which it seems would mean – I would need this replacement part? http://www.ebay.com/itm/Citizen-cal-1802-watch-movement-part-winding-stem-/361635637962
Like I said, I'm not really in a position to repair the watch myself but I'd be happy to buy the right part and hand it over to someone who could.
What do you think? Is that the part I need? If not – what should I be looking for?
Any thoughts or advice would be much appreciated – I've got a lot of respect for this community.
Cheers,
Sam
I think your investigation work looks solid. Depending on where you are based, maybe look at the Cousins website to see if they are cheaper. Stem release appears to be by pushing that small button (gently!).
Welcome to the forum. I also have some HMTs, they were the first watches for practice :)
It seems to me from the picture that the case tube is distorted which can couse winding problems, or braking the stem. One HMT of mine had the same problem. You should replace that as well, or at least remove it before inserting the new stem.
I would buy an other one for parts. It is so cheap from India lol
Hi Rodabod,
It looks like the stem broke flush with the crown. If there is some threaded portion left you could use a 'stem extender', for mechanical watches these are usually a 0.9mm thread.
Your watchguy should be able to do this but a) he may not be into mechanical watches and just wants to sell you a new watch or b- there may not be enough space for a thread extender to work. The fact that he could ID the movement speaks volumes!
You would need a new crown of course and one with a shorter tube (where the stem would screw in) would give more room for the extender. The crown tube can be teased back into position by using pliers but put something solid inside to prevent it collapsing. A new crown and case tube would improve the water-resistance as the mangled crown tube will never be water-tight.
HMTs seem to be a bastard Citizen so the stem you found on ebay should fit but I've bought a lot of stuff off the bay that don't fit!.
Here's recommended action plan (assuming you have some thread left on the original stem.. post some pics of the movement here and we'll tell you if you have enough to work with).
1. Buy crown
2. Buy a 0.9 stem extender
3. Buy a caseback opener.
4. A crown tube is optional.
Where are you in the world? Someone should be close enough to give you some tips where you can source the items. Stem extenders are available online but usually in packs of 10.
Get the following tools ready
1. Fine file
2. Side cutters
When you've got the above lined up, come back here and someone will guide you.
Anil
Thanks all – very helpful! I've ordered a new stem specifically – and if my local watch guy has trouble with that I'll just buy another hmt for the parts (very cheap as you all know).
Thanks again!
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
