Pin lever pallet fork lubrication?
rogart63
  • 1 year later...
Hello Old Hippy and Mark.   Sorry to resurrect this old thread but it's of interest to me.  I have a keen interest in the older English vintage watches which tend to nearly always be pin pallet movements and in order to get these to run well, one need s be very fastidious over set up of beat and adjustment of the hairspring, and of course lubrication.  I was wondering, what is the difference between oiling the escapement teeth versus applying oil to the pallet pins?  How is the end result different please?  Any tips on setting up pin pallets movements or lubricating would be much appreciated please.   Ps I current use Moebius 8000/4 applied with extra-fine oiling pin directly to the pallet pins, but will try Marks method of applying to the the escapement teeth next time.
Kind regards, Deggsie.
Do as Mark has pointed out. A little on a few of the escape wheel teeth, by the action of the watch it will distribute the oil to the pallet pins this in turn will oil the rest of the teeth on the escapement wheel.
and is Moebius 8000/4 ok to use?
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
