Kif spring help?
rogart63
I can't seam to get the right kif spring. I ordered one from Cousisnuk but that seam to be to small? Kif trior 1-3 . I bought a set of 25 different springs in a small box along in the order? On of the springs fitted but was broken at one of the three arms.
Is there someone out there that has a 1-4 spring i can buy or check if that one would work? A set of five from cousinsuk would cost £10
The watch works as is now but i am not sure that the broken kif spring sits tight enough  as it is very loose fit?  Maybe if i put a little glue to hold it there? But that is not a great repair that i could stand behind?
Or if anyone now a place i can buy just one spring?
Good day Rogart,
I might have that KIF trior.....gotta head to the facility today, but will check later.
J
Just now, noirrac1j said:
Good day Rogart,
J
That would be so great? Got a nice little Oris i bought for my mother at Chistmas. Going to have it serviced but running in to all sorts of problems along the way . A Oris 394.
Hey Rogart,
Glad you found that spring. I have three KIFs that I found in size 1-2, 1-3, and 1-4. I am not sure about the color coding, but I think the smallest one in the container is 1-2 .
and the other are 1-3 and 1-4 from left to right.
J
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
