I have an Omega 1010 with the brash bushes in the automatic unit showing wear.
Are these bushes replaceable - if so, does anyone know the part numbers of the bushes arrowed below ?
They are not listed in the Omega Technical Guide
U could probably use a standard size bushing? Or put jewels in? But maybe it's cheaper to buy a replacement bridge from Ebay?
Edited by rogart63
Quote
Hello Mike,
I'm with Rogart. You're better off getting a replacement bridge. I see on Ebay they have jeweled versions (maybe other calibers have them) and here is one with the brass bushings just like yours and its only $15.00
http://www.ebay.com/itm/Omega-Watch-1010-1012-1020-1022-part-1031-1033-automatic-bridges-/172222758089?hash=item281946bcc9:g:81sAAOSwintXSmKD
JC
I just realized you live overseas.....might still be a viable alternative.
Quote
Edited by noirrac1j
Saw more information
I don't know if there's anything you can use in this little box of bushings I have, but here is a photo of the contents.  I'm missing bottle 3, but I don't think that would have been what you needed anyway.  Look it over and see if any might work.  They are bronze, though, not brass.
Shirley
I am watching on ebay for a replacement bridge. The problem is with brass bushes you cannot see how badly they are worn. Hopefully a jewelled one will appear
You can replace them with brass bushings but also I have seen them being replaced with normal jewels (I think I see a Vid where Mark replaces a centre wheel bushing with a jewell setting)
To state the obvious a jeweling tool & the appropriate reamers are required for this job.
On 19/01/2017 at 8:34 AM, mikepilk said:
That's an idea. I do have a jewelling tool, so far used twice (successfully!)
But it is missing some of the reamers.
You can buy the reamers individually from Cousins etc
I found suitable brass bushes on Cousins, but If I were replacing them I may as well use jewels,
I got a replacement automatic unit from ebay so won't have to this time.
You got the replacement automatic unit....fantastic.. This is a good alternative to redoing the bushings, which you could still give a try.
Replacing brass bushings with jewels sounds like a job that most watchmakers would probably not take on if you could simply get a replacement jeweled unit at a fair price.
J
