The second watch is from India.
Buying watches from Indian sellers is a gamble as there are some real horrors out there. You need to be a bit alert and watch out for frankenwatches made out of bits of other watches.
First up.. the ebay ad.
Typical of Indian sellers, a lot of information is posted..they are usually truthful and if the dial is refinished they will say so.
I was attracted to this watch because of it unusual shape, most from this period are round.. this is a bit tonneau shaped. The dial is also original with mile and even patina.
Indian sellers often sell watches with refinished dials. Look out for painted dial in garish colours, generic markings (waterproof, automatic). Large 'Swiss made' at the bottom of the dial. Also if the dial has a raised logo (like the 'Saturn' in this watch) you may find the dial has been painted and the logo polished to bring it up.. the paint will be thick around the logo. Also Indian dial refinishers do not do the minute indices on the dial well, sometimes they leave this out altogether.  Pay attention to the hands as well, they sometimes replace them with locally produced items which are basically stamped pieces of metal, the lengths of the hands also give a clue to their originality. Below 'seem' ok but  who knows?
Something which was only apparent when the watch was in my hand was that someone had done a good job polishing the case, with radial brushing done so fine it could pass for original.
If I were to find a fault, I would say the transition from brushed top to polished sides was not as sharp as it would be from the factory.
The polisher had popped the caseback on a lathe and left a rough grain, leaving the centre graphic polished. This was probably an attempt to disguise some caseback damage, these Enicars are difficult to open as they required a custom wrench.  Personally I think its too rough and I may try try to polish it in order to tone it down a bit.
A pic of the inside of the caseback.
and the crown
Finally, heres a picture of the movement. This is definitely an original Enicar, an AR1140 as the seller indicated. Quite a nice movement, there are some markings on the ratchet wheel where I imagine sandpaper has been used to get rid of some rust, also it seems that one of the bridge screws is not original (the lower one on the barrel bridge) otherwise all seems ok.
 One thing to stay away from are watches which have no markings on the movement except for 17 jewels etc. If there's no manufacturers markings then its a 'bitsa'. Running a bit slow so it'll get a service soon.
There is some corrosion around the trough where the o-ring would go, this shows that the watch is really old and has seen some abuse in the past but the case polisher has done a decent job to get it back in good condition.
Apart from a service, I may try to source an Enicar crown as the one currently fitted is an unsigned generic one.
All in all a good buy for less tha USD40 all told.
cheers
Anilv
I don't know if its the photo but it looks like the tension ring is made up around the 2 and 3 batons. If you have the correct case opener and vice any watch case is easy to open.
    • The watch is from 1990 and was serviced just once around 20 years ago. No idea if the mainspring barrel was ever opened or changed before now.
    • Interesting but I think we have a problem here? We probably need to split hairs on a definition problem. For instance take a real Rolex movement put it in a real Rolex case but not the one it came in take a real dial real hands and make up a watch that is 100% real and what exactly is this? If you send your Rolex in for servicing and anything's been changed at all from what it was when it left the factory Rolex will be unhappy and remove all offending components. This does become a problem of people changing things because they think it's their watch and they want to have a different dial Lord diamonds the bezel or whatever words Rolex sees all of this as evil and bad as far as a Intel Rolex only things the watch is legit if everything is exactly what it was when it left the factory and nothing's been changed including the stem everything asked me Rolex original or their very unhappy about its existence. Then you think about a fake watch what is its real purpose? Well its real purpose is to make money for somebody and fool the customer. So all the watch has to do is look pleasant on the outside and inside can be anything. Typically nobody's going to see inside. So typically anything that's not legit counterfeit movement etc. why would someone spend so much time and effort making it look just like a real Rolex when there's no need to? Unless of course you have one or two movements to impress somebody with this is what's inside your watch but even that is problematic Now we don't end up with I've interesting problem that troubles me where I work. The owner will offend a cage your watch by looking at it carefully with a microscope the timing machine etc. and he will point out all the things that he feels are not appropriate correct or whatever for your watch. But in my example above of mixing and matching legitimate Rolex parts he wouldn't necessarily be able to tell. The problem I have with this is it often times things like his claim to telling a counterfeit is look at the second hand the quality of the secondhand is not as nice as a legitimate one. But maybe somebody replaced a second hand on a real Rolex. Or the other day at work I don't know what it was in before but there was a really pretty movement transparent back and they decided it was fake because of? Now I didn't think it was fake I took one look was beautifully manufactured but they had a reason What bothers me with counterfeit Rolex is or anything counterfeit watch related it is reminding me of a witchhunt. The early days of witch hunting how can we tell a which Manon which? That makes me wonder how many super fakes are really fake at all it's basically somebody deciding it's a fake based upon inappropriate assumptions. Like the secondhand is been changed or the watch was worked on the screws are perfect or other things. Other minor problems with super fakes for instance I have a long story the not going to tell the short version is I found the website once where they claim to be counterfeiting Rolex watches. They even had a picture to prove their counterfeit watch the problem with pictures online how do we know it's really a counterfeit watch and not a real Rolex watch that you're telling us is counterfeit. Oh and they had testimonials from all kinds of people who bought their watches and were very happy with the service of course the problem with the watch is you don't know what's inside it unless you take the back off and just because somebody shows a picture online and says this is their super fake maybe it really isn't a super fake they be there just trying to say that. We end up with a interesting problem of manufacturing a watch. Does Rolex actually make every single part found in their watch? Then the year 2004's basically irrelevant. This is because initially Rolex buys stock in the company and they manufacture Rolex watches. I'm assuming over time Rolex will acquire more stock and only in 2004 do they get the whole company. But the company itself hasn't really changed other than the name on the front of the building. The real question is did they really make every single component found in the Rolex watch from the beginning of time until end of the time? A lot of the components found in a watch would be extremely specialized did they make their own jewels or their own mainsprings for instance? But that is looking at the article they employ a heck of a lot of people now I would guess now that Rolex probably does make everything in-house. Especially when they have nifty CNC equipment like for making screws were he could make a huge batch of one type it instantly switch to another type where before he needed specialized machines for one machine for one screw now manufacturing all kinds of stuff in-house becomes very simple. But still is possible that in the early days they might have outsourced something may be perhaps. But conceivably we do have minor changes in thing is due to how things have been made over time which can lead to confusions over whether this is legit or not when it may be as a change of manufacturing methods oh and regarding the screws found in your Rolex watch? In about mid-80s I went to a school reunion in Switzerland. One of things we could do was visit a factory and I picked Rolex because I wanted to see the mass production making of Rolex watches. Which is very disappointed I did not get the sea at all because didn't see them making Rolex watches in their Geneva headquarters even though the building is really fake? So what did we get to see well after sales service because after all were watchmakers we should see that. Did learn something interesting about Rolex screws if your watch was sent to Rolex the screws that come back are not the ones that went there. As they are using powered screwdrivers they don't want to risk breaking heads off and they will replace the screws of every single watch. The other one of interest was suppose there's a scratch and you can see the brass? No problem they have a solution that basically electoral plates without electricity so the scratch goes away. The research Department was quite boring and didn't look like anyone was ever there. Then it was too long ago to remember all the details other than I was disappointed I want to see manufacturing.   Yes the joys of artificial intelligence that is more like a trained monkey that's there to please you.
    • Hey everybody! I just registered to WRT. I found this forum searching for informations about ELMA watch cleaning machines (will get one ELMA tomorrow ✌️). I'm new in watch repair, collecting watch repair tools to fill up my work space 😎.   Greetings from Vienna Michael
    • Is it not covered in the manual under Profix Cap Jewels?
