Bad start to 2017
clockboy
It,s was my fault I left my workshop ajar last night and found our cat asleep on the window seal this morning. Had a quick check around the bench and nothing was broken and looked ok then !!!!!! I stepped on this wheel. It is from a very cheap (wife paid £5 for it at a fair) Enfield Smiths westminster chiming clock. I have posted a couple of pics of me trying to straighten the pinion and it is almost straight but I can not see how I can rivet the wheel back on as my punches are not deep enough to fit over the length of the pinion. IMG_1046.jpgIMG_1047.jpgIMG_1053.jpg
Good idea Mark yes I have one so I will give it a try. Getting the shaft absolutely straight will be the next challenge
What fun !!!!!
Lol
Good luck - I have every confidence you will repair. :)
Here's another idea, create a larger seat for the wheel.
Make a brass collar that you secure onto the arbor that has a wheel seat centered over the old position. The seat itself will be larger in diameter than the old seat to give it strength. Secure it with locktite. Chuck up the arbor and turn a new seat and a decorative back end.
Once its made  mount the wheel in a pot chuck to open the center hole to fit the new seat diameter. Stake it on normally.
Al Takatsch
2 hours ago, oldhippy said:
Can't you drill the stake out. Its a very common movement as you know so there shouldn't be a problem.
I did think of that but I presume the stake will be hardened steel. I have found some Clock punches in various supply houses wondering if the holes are deeper to allow for the pivots.
Al Takatsch
Thats also a good idea but will I have the issue when staking the new seat i.e. the pinion is to long for my punch.
Well I suppose I could but the stake has to be domed & hardened. This is possible but a big job for a clock that cost £5. However if I can get the pivot absolutely straight I will try to solder the wheel onto the pivot.
Family commitments for the next few days but will keep you guys informed of the progress (if any!!)
7 hours ago, altaka said:
I have a lot of Rebarb steel used to strengthen concrete. 1/2 inch would do it and its soft. It will turn quick in a lathe.
Do not need to harden it because you are staking brass to brass
Al T.
Thanks family commitments stopping progress for a couple of days. Lots of options suggested with this but the priority is to get the pinion absolutely straight because other issues will surface if not.
Al T.
Don't you mean rebar steel.
Just an update with this. I just could not get the pinion perfectly straight & also I found the wheel was also out of true. I did a an experiment for future reference & soldered the wheel to the pinion which works a treat so a useful exercise.
However I have now purchased a donor movement for the replacement wheel.
What fun!!!!
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
