Hello everyone and happy new year!
I'm working on a beautiful 6139B that I bought not working. The first thing I noticed was there was a missing intermediate minute recording wheel which I just got. The second thing was the central chronograph wheel complex.
I've done some looking around and unfortunately I have come out empty-handed in terms of any ability to repair the wheel. The tech-guides have limited recommendations other than replacing it when damaged.
Here are a couple pictures from it where you can see that the disc between the Chrono and the wheel is way out of flat.
Once assembled the watch will run pretty well with the chronograph activated. When The chronograph is stopped the train comes to an abrupt stop with it. I figure the damage wheel is not contacting the mechanism when activated.
Anyway, I was hoping to hear the experience of anybody trying to repair this part.
Cheers to 2017!
Good luck :unsure:. Never ever heard or seen that done? Maybe just maybe you could try put it in a staking tool and put some pressure on the top and very gentle try to bend it back. This wheels aren't repairable? Look for a used one on Ebay? Have seen but not sure if any is available at the movement? But no harm trying to straighten it anyway? chronowheel.jpg
Edited by rogart63
I have a rusted movement coming but I'm not too excited about it housing a working center wheel but it would be great!
I wonder if it can be put apart of should I give it a go at the risk of damaging another element....
There's a pristine replacement on eBay but for $88 [emoji15]
There are springs inside the wheel that are in tension? If you try to take it apart they will release and you can't put them together again.
I was thinking of how it could be bent? But probably one of the levers has been on the wrong side of the clutch ring? Bending it upwards.
I agree with you completely. Either the lever got loose over time and the pusher was forced or when they tried to service it the lever was left on the wrong side and when activated it just bent the wheel.
It's a shame because otherwise he movement is pristine!
8 minutes ago, ro63rto said:
Also Adrian over at VintageTimeAustralia. Postage costs are reasonable even to me in UK.
At least he could give you some advise? He is a very helpful guy.  Check Wristsushi out? A forum for Seiko nerds :)
At least he could give you some advise? He is a very helpful guy.  Check Wristsushi out? A forum for Seiko nerds [emoji4]
"We" are NOT nerds.
We prefer to go by WIS [emoji4]
"We" are NOT nerds.
Quite right! And if we are allowed to mention other specialist forums then as well as Wrist Sushi I'd also have a look at the Seiko and Citizen Watch Forum at thewatchsite.com which is also full of us nerds, oops I mean WIS (although I'm a long way from being able to call myself that!)
The Seiko 6139B part # for the complete center chronograph wheel is P/N 888612 .
The 6139B comes in a 17 and 21 jewel version . The chronograph finger that sits on top of the wheel is P/N 786610 and can be replaced as these are delicate and have a tendency to break . There is also a part called "Rest of chronograph finger " and that is P/N 787610 .
I looked up the the the part # for the complete center chronograph wheel for the 6139A , and that is listed as P/N 888610 , although the the "finger' and "rest" are the same P/N for both the A and B versions .
While I was at it I looked up the center chronograph wheel for the 6138 A and B  . That uses P/N 888611 .
I checked my watch parts interchangeability list and the parts aren't listed as interchangeable .
I found these complete units on the bay....new and used...
I didn't see Seiko listed on the Old Swiss Watches website , but I would email Sudarson and ask him if he has them .
I would also email Ramon at TheWatchCollector website because I know he has parts .
Good Luck ,...Louis
Good Luck ,...Louis
Fantastic! I had come across the 2 used ones but not the last one. It appears to be type B! I've messaged him to confirm.
Thank you for the great info!
Good Luck ,...Louis
After trying to repair on the staking tool... I was able to bend the wheel close to normal, I assembled it again and now it runs both with the chrono function on and off, but it grinds to a stand still just before the minute is up.
So, while other information comes to light I've given in and bought one of the ebay options. There's not much out there!
Thank you all for your comments and suggestions!
A while back after servicing a 6138 or 6139 , I don't remember which , my chrono second had would stop at the 58 second mark . I did some reading and found out that this was not an uncommon problem and I was able to do the adjustments that are in the troubleshooting section of the 6139A tech sheet . I think the adjustment is for both calibers . As I said , it was a while back . Also I remember replacing part # 893612, the intermediate recording wheel holder . It's a bushing that's attached on one of the plates by a screw .
I have attached some tech sheets in case you haven't seen them .  Checking and adjusting the chronograph mechanism starts about Page 8 on the second attachment and troubleshooting is a little further  back .
This may be a moot point since you bought a new part , but there's some good info in there anyway .
  6139B.pdf
Great One- 6139A.pdf.zip
  6139B.pdf
Oh this is totally worth it! I will dissect this chrono wheel open and post the results of the autopsy. [emoji1317]
  6139B.pdf
  6139B.pdf
That is probably only adjusting the levers? You will have to look in the pdf how you do that?
I thought so too but I made sure that when the chrono function is on the levers aren't touching the clutch at all and it still stops, I assume when it comes to the uneven portion of the clutch wheel.
At least you have tried everything? Hope an other wheel will work?
Edited by rogart63
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
