Dad's watch
Santa came through this year with my first real tools. I replaced the movement in my dad's watch, the one I broke when I was about 5 by winding it all of the time. I found a used movement, the exact same one that was in it to begin with. It cost me $15 including shipping all the way from England. It started ticking again on Christmas Day for the first time in 38 years. I wish dad was still around. He would be tickled pink. He loved this watch. Nothing fancy to most, but it was to him. I've been wearing it for 5 days now. It keeps perfect time, and it turns out I still like to wind watches. I'll be more careful now though.
  • Like 5
A man's watch is his only jewelry and it is irrelevant how much it cost or what brand it is.
It's personal and there's only one like your fathers and that makes it unique.
Its a bond to the past that cannot be replaced or completely understood.
Well done and enjoy !
PS. Please be kind and don't over-wind ;-)
14 hours ago, atimegoneby said:
Well done !  it must have been quite a moment to see it running after all that time,
are you going to repair the original movement ?
The original, for now anyways, will be something to practice on. I took it most of the way apart today. I'm having some trouble getting it back together right now. The escapement wheel and the (can't remember whatcha call it little forked thing that stops the escapement wheel) are both tricky to get it right it seems. Its like a puzzle. I'm sure it will come along eventually.
5 hours ago, rogart63 said:
Great done. Fantastic work.you done.  What  movement? Never seen that brand before? There is a newer watch brand called Helberg but never heard of Helzberg?
Its a UT 29c movement. I don't think they make it anymore. I bought this one used, but it works fine. The original had a broken mainspring, which I ended up misplacing, so I can't measure it to get a new one. The replacement was cheap anyways.
Helzberg is a chain of jewelry stores over here. There used to be one in Duluth, which is probably where this one was purchased originally. I'm not sure it my dad bought it, or if my grandpa did. My aunt seems to thing this was my grandpa's watch and my dad inherited it after he died. That would explain why he liked it so much.
That explains why  only jewelry comes up when i google the name :) .
I checked ranfft.de  and according to them a seiko mainspring should work? From a 66 A movement. Not that difficult to find?
The movement actually looks very much like a Seiko clone?
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&UTC_29
Edited by rogart63
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
