7750 Crown Hunt
jdrichard
I have just reassembled a 7750 and now need a new Crown. I have looked everywhere and they just don't exist. It has to fit a 1.2mm stem (cousins calls this a TAP 12?) and the externally threaded tube of 4mm. I think the rest of the world calls this a TAP 7??
I went the Cousins, Eslinger and Ofrie and found zip. Any suggestions.
Iwc 7750's are designated different calibre numbers and a number of variations where produced from a heavly modified grand complication Cal.79091 to the split seconds doppel chronograph cal.79470 also in the Aquatimer split seconds.They where modified by IWC, it may be easier to search the net via Model variation rather than movement.
Edited by wls1971
The following site lists every 7750 based IWC calibre and then shows every model that used that particular variant, its a very useful site for checking which manufactures use which base calibre and the calibre numbers that particular maker desiginates similar to the Ranftt site.
http://watchbase.com/calibers
Alethea great resource thanks
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
    • Hello As I am learning, does anyone have any recommendations  on Repair and sourcing in Gold Coast, Qld, Australia ? eg old Seiko coil 4002920 Thanks. Cheers, Ken
    • Is this what all you're looking for?
