2 hours ago, ro63rto said:
Seiko Perpetual Calendar
Man you are good! Found another like it with 7019 21j auto, appears to be pretty scarce model. Thanks again guys!
I don't think this counts as a 'perpetual' calendar in the same vein as the higher end watches which not only show correct dates for each month without manual intervention and can even take into account leap years.
This watch can only show the correct dates if you manually change the inner ring... hence not perpetual.
You can see this sort of calendars in some Orients and even built into some stretch bands from the 60s.
Interesting all the same.
Anil
Anil
Not as scarce as I thought, last bid on the one I posted was almost $200 usd, way out of budget for me, still a unique piece!
1 hour ago, ricardopalamino said:
Stupid computers.....
:startle:
:startle:
These are not uncommon at all and you should be able to find a much better price .
I'm still not sure I get the point of these. If I understand, the upper crown turns the extra day ring, but does that effect the day/date in the window? Or is it just so you can see what day a certain date falls on this month?
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
