Everything there?
rogart63
11 minutes ago, praezis said:
Yes, should. And I can see one, big and black! :)
I was wondering if there should be anything like this at the end of the handle?
Sorry if i didn't have the right word for the whatever it's name is? 190.jpg
Edited by rogart63
I've not seen one like that Roger, but I suspect that the six mandrels are fitted into the end of the winder where the knurled locking nut is.
You will select whichever mandrel and winder unit that suits the spring and lock it into the winder by tightening the knurled nut.  This is now effectively the crank that you think is missing.  Attach the centre curl of the spring to the manderel, then place the winder unit over the spring, then wind the spring into the unit by turning the long knurled shaft.
Once the spring is wound completely into the unit, remove the unit from the end of the winder, and press the spring into the barrel from the unit.
this is my take on it, I may be wrong.
So looks like you're not the first person to ask how to use these. So first link I was hoping for a better picture but slightly better and second link much better pictures.
http://mb.nawcc.org/showthread.php?30820-Howd-does-this-watch-mainspring-winder-work
https://veiling.catawiki.nl/kavels/3555435-verenwinder-van-brugger-turzynski-in-vintage-doosje
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
    • Hi. That explains it, done that myself.  Leve the movement open with the back off and battery out for a few days in the sun and let it dry naturally, re fit new battery and try again if  it is not successful the circuit block may be toast,  Better if you can get the movement out of the case for drying what is your location
    • Thanks for that. He's worn the watch daily for the last 20 years, he said he didn't even think about it being on his wrist, because it's always there. He had a shower and when he got out he noticed the crystal has condensation on the inside. I may have exaggerated when I said it was FULL of water 😅 I removed the movement from the case last night and there's no sign of water on the coil or battery, however the dial has dried water spots on it. I'm not sure about stripping the movement further, I've never done anything with a quartz movement. I tried looking for a donor movement but they seem to be practically non existent. Even Jules Borel doesn't list this movement in their parts catalogue
