Hi guys, I found a LWO283 on eBay for a very good price, so I thought I'd pick it up and try and service it.
For those that don't know this movement is an ETA 2892 with a Dubois Depraz chrono module.
I've serviced a 2892 before so interested in having a go at the module.
Anyway, slight problem I'm not sure how you remove it from the case. At 6 and 12 I have turned the two tabs so it's no longer latched in. Taken the stem out. And it's not moving, I don't want to try random screws and remove it. I need to be confident on how it actually comes out.
Any ideas?
I'm sure it does come out the front.  The two "tabs" that you mention look like rotary knives that cut into the dial pins to hold the dial in place.
I think you will have to remove the front bezel (if possible) the or the crystal, the screws that hold the movement into the case. From what I see it looks like there are three of these screws.  Once the above has been accomplished, the movement should come out the front of the case.
Thanks for that. I've got the bezel off, I can't seem to get the crystal out though. Should it twist out or do I need to prize it out?
Using a crystal puller or suction cup seems a better idea.
Can it be done without these. The case/crystal is going in the bin
The bin is something unknown to watchmakers [emoji4]
I suggest that you try to do things the proper way without using force or breaking things. It is part of a quality approach to this hobby.
That'd be the tool - assuming you have a domed acrylic crystal with enough to get a hold of the egde.
The tool is also good for fitting new crystals... but I had to deburr the claws on mine to prevent marking the crystal when I first got it. I suspect if you buy the bergeon version then this would not be required!
You might get away with blowing the old crystal out - not so easy with a chrono case, but it is accepted practice to use a small pump on the pendant tube. There is again an expensive solution to this problem (below) or you could improvise with a bicycle pump, ballon pump, syringe, etc.
https://www.cousinsuk.com/product/glass-removing-pump-bergeon-5011
Hi Stuart, thank you for your detailed reply.
I've just checked to specs for the watch (Philip sea lion) and it has a sapphire crystal. Would that require a different type of puller?
If you have a case back press fined a dye approximately the same size of the Crystal not the bezel. If you don't have a case back press, improvisation is required, possibly a plastic bottle top ? Hold the bezel firmly in your fingers, face down. Place dye over the inside of the Crystal. A short sharp positive hit to the dye with a suitable hammer will release the crystal from the bezel.
Sent from my SM-T585 using Tapatalk
If I have understood your explanation correctly I don't think I can do this because the movement is still in the watch, so I can't place a dye on the inside of the crystal.
Ooops I thought the bezel and crystal was off the case but you will need a decent case back and crystal press to fit the new crystal. So you have removed the bezel and the movement is still in place with the crystal over the dial ?
Have you tried pushing the movement from behind out the front
Yes that's correct, movement is still in place. I haven't placed any pressure on the movement. I don't want to put pressure on the movement to push out the crystal. I need a tool to remove sapphire crystals from the outside.
If the crystal is attached to the case, not the bezel, then this definitely comes out the back.
If the movement will not rotate in the case, it is likely you haven't freed it yet. There are 3 other large screws around the edge of the movement, are these the retaining screws?
Stuart, I think I've reached a point where I'm just going to have to remove them and find out. I was kind of reluctant to do this without knowing for sure. I thought the two tabs at 6 and 12 were for holding the movement in place, I've not seen an ETA movement where they use a screw as well, however I have very limited exposure as I'm just starting out. I will remove them and report back.
If life only was that easy. A high number of watch producers buy in movements and fit to cases in a variety of ways. If after removing the screws it still doesn't want to move. It still could push out to the rear, including the crystal, or the front, note the size of the dial diameter and what way it's likely to come out. It could still be the screws holding the movement in but after removing, dirt is holding the movement in. There could be a movement ring holding it in position or the movement may need to be rotated first prior to removal.
Best of luck anyway
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
