Yes, you need to replace it, otherwise you won't be able to regulate the watch.
They are rivetted in, so you will see a domed head on top of the lever... cut this off with a scalpel and you should be able to push the pin out.
Cousins sells mixed packs, but they make them hard to find - search for S37393
Fitting the new one is a bit more tricky. You may have to make up a special anvil with a hole for the boot and the pin so you can rivet over the end.
Once you've done this you can cut the pin to length and adjust the gap so the pin is parallel to the boot and the hairspring just fits.
Alternatively, if you can track down a replacement lever, that is quicker, easier and cheaper, but less rewarding!
S
For me the repair is easier this way: drill a hole through the rivet with a small pivot drill, push in a conical hairspring pin, shorten to right length.
Frank
Thank you all for the ideas. I'm not sure what a pivot drill is - I'll look in a catalogue. I probably need some kind of a staking took eventually...
I'm cleaning another watch. The only way to do it is to clean off the grime and rinse - repeat until clean. No fun at all but, as my watchmaker friend says, "Who told you this is fun?"
This stuff all looks so easy in the videos.
Dave
I would get a replacement if it where just a Seiko 7009 movement . But if it was a Omega or Lemania or something like that i would probably do it?
On the other hand it's good practice to have done it on a Seiko when you need to do it on a Omega?
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
