staiger quartz astronometer
graham123
hello back again.managed to get this staiger clock from a auction,and really pleased with it.i have never come across this type of clock before,so i intend to keep it.the same auction had a vintage walker time grapher,again never seen one before,and think my friend bought it.sorry about no pics,i really struggle to upload pics
10 hours ago, graham123 said:
thanks clock boy,this was the auction picture i used.the case is good old hippy,and all the functions are working well.i am guessing the clock was made in the eighties,with a limited manufacturer run
I would think that is a safe bet around the 1980's. If it is a limited edition it should have a number with some sort of paper work, a limited edition could be any number, a clock could be made in its thousands and still be called a limited edition.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
