The practicality of bluing
TimFitz
Assuming that the parts you want to blue are steel there are two approaches to bluing.
The first is heat which I would not recommend as you're going to need to get a lot of heat into it and the chances of warping or otherwise distorting it are high, let alone the risk of adversely affecting the hardness of the frame.
The second approach is to chemically blue it using a treatment that is applied to the surface. As a teenager I used to restore vintage air rifles and tried a number of the proprietary preparations with varying degrees of success. The most critical factor seemed to be degreasing and absolute cleanliness in order to avoid a blotchy and uneven finish, but if I got that right then the results were fairly good. You will need to ensure that the surface finish is even before you start though, either a really good mirror polish over the whole surface or an even grained or brushed finish as any variation will be very obvious in the finished item.
It has been a (very!!!) long time since I played those games though so I'm somewhat out of touch with brands that are available, your best bet might well be to browse a couple of gunsmithing forums and web sites to see what the current state of the technology is.
Also, it might be worth waiting to see if Geo has any input as I know that he has also had some gunsmithing experience.
Another alternative might be to use what I think is called black lead. I know nothing about it or how it works other than that it used to be used to keep cast iron stoves and fire places looking good.
As usual I agree with you Marc.  Preparation is everything, the polish, degreasing of the item and the careful even application of the blueing medium is all important.
I used to use a cold blue for re-touching  the finish on target firearms I worked on, it was quick and easy and gave a very acceptable result regarding appearance. This does not give a finish that is anywhere as durable as the original finish and will have to be re-applied now and again.
Here is the brand that I use.
If you decide to use this, remember to rinse all the blueing fluid of then blow dry.  Once dry, oil the surface to prevent corrosion.
Tim
A process called rust bluing is the way to go. It's very easy and looks beautiful,  but it is a process that needs to be learned. Again google and u tube are good resources.
I do a lot of it, I have been restoring vintage firearms for a while now. I have a cottage on OAK Island and would be happy to walk you through it next time I'm down.
Tom
Chemical bluing is the way to go.
A couple of years back I was working on making John Wilding Foliot clock, attached is a photo showing one weight before chemical bluing and one after.
The bluing is still perfect on the weights.
I just visited a local gun shop and asked them for gun bluing chemical.
    • Off topic, but that just brought back an old memory! My mother once told me about a minor incident as a child (born 1917, so 1920s, at a guess). She used to use "Fish glue" for a hobby - an apparently smelly glue that had to be heated to be usable - and to heat it gently, she had to stand the tin in the kettle.   One day someone filled the kettle without seeing the glue tin.. The tea tasted of fish for some time afterwards!
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
