The third wheel jewel need to be replaced I think. Is this a typical friction fit and do you think I should replace this jewel?b90f9f821c7f524a2fc2c72ddb3ef571.jpg4d95c1382aeec93fd7b9277d8ac9df54.png
Can't tell from these images if it's a rubbed in or pressed in jewel - you need to look at the outside where you apply the oil.
If they are rubbed in, then assuming you have the tools, the hard part will be finding a new jewel. You need to open the setting before removing the old jewel.  I spoke to a local watchmaker about this and his advice was that money was better spent on a donor movement than buying collections of old jewels as most of the useful sizes have been used up.
1 hour ago, szbalogh said:
Half minute fatser :)
The OP has rubbed jewels.
Well, I too thought they were rubbed jewels and then I thought it must be a view of the flat side of the jewel so not possible to be sure...
If it's rubbed in, what should the other side of the jewel look like so I can have a look and compare. I do have the tool to open the setting g but do not have the tool to close and burnish it closed!
One can use a hollow stake from the set or grind a hollow punch with the desired pitch and diameter. For the 4 jewels i replaced until now i had to make 2 stakes. Soft steel will do, use oil while opening and closing the setting!
Thanks for the help
