Today's overhaul
31 minutes ago, Brian3 said:
Spending a pleasant Sunday afternoon overhauling a Rolex 3135 at home, nice to work on as it goes together so well with bridges practically falling into place.
I have never had a Rolex, what would be a good first watch?
Rolex are generally very easy watches to work on Tim, little issue of course is just the costs of the watch and not getting spare parts unless you have a parts account with them. Other than that they're a walk in the park. Nicely machined and fit together real well.
Excellent! To remind anyone that this is watch repair forum :)
Any timegrapher pic to show how a Rolex moment behaves ?
This happens to be my Submariner, just finished casing it up, twelve years old and this is the second time I've overhauled it, running great with a delta of 3 seconds.
Fantastic. I just love to see timegrapher pictures for my education, welcome to share any,
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
    • Yep Mike , i use exactly the same gauge for it.
    • You definitely pick up different names from different people of all ages from everywhere. Like learning different dialects of the same language. Its all part of the learning curve of any trade.  Both those two terms describe to me perfectly that they are one and the same. After a couple of years of knowledge you can figure out what is being talked about. There are times that i get caught out with something i haven't encountered before.
