I recently go a Breitling Aerospace Quartz F65062 however unfortunately it’s not working and I got a refund.
However I’d like to get it fixed up but I’d rather not pay the £400 Breitling has quoted me so I was trying to find an independent that would do it however it has been harder than I thought it would be. I don’t need it cleaned, pressure tested etc, I can do that myself I just need it working.
Anybody know where to turn?
A little confused on your first point, you bought a watch and got a refund without returning the watch?
Anyway it all depends on those aerospace movements, they're all listed as 'breitling <double digit numer>' could be that they're effectively re serial numbered ETA's, you see that sometimes, or it could be that they are indeed, made in house, which wouldn't surprise me, if that's the case I don't think any independent will be able to acquire the requisite parts to effect a repair, if movement parts are faulty.
Maybe someone knows something I don't, though.
Edited by Ishima
I bought it believing it to be working however when I replaced the battery I found it was not working so I got a refund to bring it down to the faulty value. I could probably still sell it for more however I’d really like to get it working again however I don’t want to get an extortionate bill back from Breitling.
From the jewellery shops I have contacted that do in house quartz repairs they all say it will need to go to Breitling. I assumed that an electrical engineer or computer shop may have branched out into quartz watch repair but I guess not.
On 10/10/2016 at 2:29 PM, SSTEEL said:
Is this the ana-digital model that shares a Timex ana-digital movement?  H01 or something similar.?
Do you have a photo of the watch?
This is a picture of the watch that I lifted off the internet.
And this is a picture of the actual movement in the watch I want fixed.
If it as an  ETA 998.332 as mentioned above could I simply buy a new  ETA 998.332  and changing the hands and dial over?
Correct, find yourself a manual too, so you know how to set it up when its running, whilst the movement is out, check all pushers are operational, and bot seized.
998.332 won't work as the digital display is different(smaller).
I've tried to fit the 332 in your watch and although it fits ok the digital display is far too small height wise.
Try looking on eBay for an equivalent movement.
Failing that try and find an accredited Breitling workshop who will sort it out for you.
The movements,if you can find them,are relatively cheap at around £150
Fitting them is ok but aligning the hands can be quite a lengthy process .
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
