Seiko 6106-7589 In need of face transplant
tjg79
Hello Forum,
I was attempting to clean a bit of crud off the face of my Seiko 6106-7589 with isopropyl alcohol and a cotton swab and was surprised to see that the alcohol dissolved the finish on the face. You can see the "white spot" at about the "10" position. I'm looking for recommendations to fix this error.
Is there a good source for a replacement face that would fit this watch? I doubt I could find a NOS face.
Another alternative would be to have the original face refinished or clean it all off to make it even.
I've attached a few pictures so that you can see the extent of the damage.
Thanks for the assistance.
Regards
I've had a saved search on eBay looking for a good donor watch candidate. But, the problem with that is most are good watches worthy of keeping together or they are in such sad shape that the dial isn't good for transplant condition.
Keep an eye out on Thewatchcollector on ebay.
Sometimes Ramon has some nice donor watches that look like junk BUT a decent dial hides behind trashed crystals.
I have to ask....
What made you think it was ok to use what is essentially a solvent on a painted surface [emoji1] [emoji4] [emoji6]
I've just made a $10.00 eBay best offer on a 6106-7589 donor that is questionable, because I see a bit of rust or corrosion on the inside and the crystal is so trashed that you can't made a good assessment of the dial.
As for my error of cleaning the dial with alcohol, I wasn't thinking clearly. At first, it didn't seem to affect the dial. I though it was something on the level of anodized aluminum. It was only after I attempted a bit of scrubbing with a cotton swab on one particular spot that the finish was destroyed.
What is the approved solution for cleaning a dial?
Thanks anilv,
There are some nice looking Seiko 6119s in good condition on eBay. But, I can't bring myself to cannibalize a good condition watch to fix my watch. If I see one that looks trashed, I may make an offer.
Regards
Thank you for the offer Tcarpilot.
That is a nice looking dial. If it had silver accents, I'd accept your offer. Since my 6106 is basically a silver watch, I'm looking for a dial that will more closely match my original color scheme.
Thanks again.
Regards
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
