6306,6309 oiling question
rogart63
7 hours ago, ausimax said:
They only work when setting the day/date, I don't oil them.
Okay. That would be nice if that would work? But they could be used really often if you don't use the watch every day? But on the other hand i have seldom seen any that was worn?  Some Lubeta 105 could work?
What does Seiko recommend?
https://docs.google.com/viewer?a=v&pid=sites&srcid=Z2xlYXZlYW5kY28uY29tfHRlY2huaWNhbHxneDo1OTk4NDUzYmM3ODEzMzJi
Says normal quantity but which oil i can't see. Only black and white pdf .
Edited by rogart63
It indicates "Normal Quantity of Moebius A" which I believe translates to Moebius9010 although I would love to hear confirmation of that as this whole oil business is new territory to me. I was lucky enough to find the colour version in my hunting for info which I have hopefully attached to this post. Note: I can't remember where from so I can't be sure who to credit with the original upload, so apologies to the OP.
24._6309A.pdf
Edited by Pip
Yes, Moebius A is 9010. As I've mentioned above, it's a better choice than HP1300 for this particular application (reaching to  arbors of permanently attached wheels), because being a fluid rather than an oil/grease, it will alcually reach to the part to be lubricated. Seiko still recommends the same for the current movements, and to ease access, the wheels are manufactured with recognizable cuts. Check illustration *2 on page 3 of the attached.
NE15-TG.pdf
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
