Hello , i would really like an advice about this awesome watch. Since i was for swimming got some fog on the glass , i removed the screw pushbuttons , cleaned and lubricante them . The small rubber seals were in excelent condition but as you can see on video i still get some bubbles coming out , not as many as before but some.
The question is , are these bubbles capable to destroy the watch by swimming?
can i find new rubber seals for the push buttons to replace them, would they make it sealed?
The case numbers of the watch are 178 0523 and on the antimagnetic iron writes 096 FE 0029 , omega profesional seamaster chronometer 300m
Thanks in advance for the help :)
omega_seamaster_test.mp4
Thanks a lot rogart , i allready registered in cousins , found the code you suggestedĀ  , the price is a bit bitter thoĀ  , 11 english pounds each and i need 4 , well at least i can try replace them. Thanks again rogart
Hi Parmenion,
I suppose that if you want to put something there it should be Silicon Grease...Being an Omega, I would send it to a professional...maybe to the official service center since you are really using it" If it was like I do mine (it sits in my collection hardly getting wrist time), I would not worry about it....Now, the point is, you got already humidity in the watch, that's no good so a service is required...full service for peace of mind. JMHO.
Cheers,
Bob
PS. It will not beĀ a cheap maintenance though!
If the threaded tubes for the pushers come out they should be thoroughly cleaned and replaced back into the case with a little red loctite, the pushers themselves are ok to leave dry but you must lubricate all the round gaskets on the pusher assembly with fomblin, this is how they are assembled and overhauled in the service centers.
I totally agree with bobm12, if you've got some moisture in that watch get it serviced pronto, failing to will be asking for rust to develop and nobody wants that in their nice time piece.
It'sĀ a nice watch, look after it.
Meant to say don't remove the pusher tubes if youĀ don't need to, they more than likely are not the cause of the leak you are experiencing, I would expect it's within the pusher assembly itself, fomblin on the gaskets there will be adequate.
Looking at the condition of the watch in your picture the pusher tubes will be perfect so leave them in.Ā :)
i want to really thank you Bob and Brian for your replies.
The bubbles watching the video i posted when i try the waterproof test came out from the push buttons so i thought the problem is the rubber gaskets , i cleaned very well the stainlessĀ  steel tubes and put new gaskets but some bubbles still came out.
You bothĀ  made me think and i ordered a red loctite and a novostar push button grease from my local dealer , he didnt had fomblin :( ,
I was using waterproof silicone grease, i hope that was the problem.
Overall cant see any bubbles from other spots coming out.
I will keep you updated, thanks again.
Ā
You could probably get some generic gasket that will work?Ā
Ā
I don't know, in my book, it doesn't matter what you use the watch for when in the water. Swimming can generate "instant" pressures that exceed the rating of the watch...In this case, your watch rating might be OK for more than swimming but the fact that its water tightness has been compromised and any humidity inside a watch invites disaster, I'd still sent it to a pro for a full service...you are saving pennies now, you will spend dollars later!
The lower pusher is leaking slightly. I have not worked on this calibre but aĀ new seal I expect will be the answer.
Until then do not use in water.
Thanks bob and clockboy for your replies. You are right , the watch must goĀ  to aĀ  profesional .
It wasnt only money matter but mostly the eager and the oportunity i had to say "i fixed it my self"
Check that in another thread yesterday someone ha resolved a leak from the pusher simply using another type of lubricant. Certain things are easier that what they seems.
Hi parmenion,
My take on this: if you pulled out the pushers (hopefully you did to put the new seals in) and greased those with proper grease,Ā and then put it all back together, chances are a pusher is not completely straight. Even with new seals a bent pusher might compromise the water tightness...there goes the pennies and the dollars! I hope it is not that!
Cheers,
Bob
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725Ā mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then theĀ scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.Ā  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles., Ā not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg Ā  You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver. Ā  Depending on the Crown material and Stem material, you can try dissolving the stem.Ā
