Hairspring attachment
TimFitz
Hi
I have a Waltham model1883 Special size 18 15 jewel pocket watch I'm working on at the moment. The roller jewel is missing so I just started to take it apart to fit one , when I noticed the hairspring wasn't connected to the collet that connects it to the balance staff. The collet is there just not attached to the spring.
I haven't dealt with this before and would like to know is it possible to connect the spring to the collet again & if so how. Or do I need a new hairspring?
Thanks for any help
The hair spring is usually pinned to the collet in much the same way as it is to the stud at the other end so it's perfectly possible (if somewhat fiddly) to re-attach it. Whether or not it's a good idea depends on why it has become detached in the first place.
If it has simply become in-pinned then there should be no problem. You will need a brass taper pin, fine tweezers, a very steady hand, and the means of removing the excess taper pin once it is in place.
If on the other hand the hair spring has broken at the collet then there are two major issues to resolve.
1. You have to remove the existing taper pin and the broken end of the spring from the collet. very fiddly and you might be better off with a new collet.
2. The old hair spring is now too short. You will need to reshape the inner coil to fit the collet, and then add weight to the balance to bring the timing back into spec. You will probably need to reshape the outer coil as well to bring it back into alignment with the regulator.
Fiddle but not impossible.
I have been reading the Raul Horology blog with interest from the beginning lessons at his watchmaker school .
Attached is lesson 1 of assembling a hairspring to a collet and stud .
As Marc has pointed out , it is a fiddley endeavor .
http://raulhorology.com/2012/10/the-mark-of-a-true-watchmaker-forming-hairsprings-part-1-pinning-flattening-centering-2/
    • Interesting, but not very accurate, unfortunately. Using the word "Radiation" without specifying the specific type of radiation [what is being radiated] is one of the commonest mistakes - and most confusing to non-technical people.  Also, I believe the commonest lume in general use nowadays is just a phosphor compound that is "charged" be exposure to light? I've never personally see a watch with tritium lume, and it's not something I would particularly want as the decay is quite rapid with a half life around 12.5 years. Tritium is also of course radioactive, emitting beta particles, and it can possibly cause cancer if ingested!   Re. geiger counters, it's also important to note that many on internet sites are fakes that detect RF rather than, or as well as, ionising radiation. Or just low quality that likely only detect gamma, or gamma and alpha. Only high quality mica window GM tubes will detect beta; all the cheap geiger counters I can see on on ebay at present that show the tubes, use glass or quartz - despite claiming to detect beta
    • Some things that we think of as relatively new or modern have been  around for a very long time. Alloy mainsprings, balance wheels and hairsprings and epilame for example were developed over 80 years ago. I use clear nail varnish for glueing crowns on, as well using it when making fibre bristle oilers and tweeking tools, its easy to apply if you get a move on after taking it out of the bottle and sets nice and hard.
    • Hi you will probably find there are a few citizen movements the same or close due to manufacturing processes.
    • Hello, How do I open a screw back cover on a hidden lug watch? It is perfectly round and rotates in the watch holder.   Thanks!
    • Where abouts north east chief ?
